Old 03-16-2012, 06:17 PM   #1 (permalink)
heading for 40
redorchestra's Avatar
Hong Kong MTR - '98 Bombardier/ nee Adtranz A-Stock 5 paired doors
90 day: 102.63 mpg (US)
what would this do?
what would this do? aerodynamically spaeaking ? would it be good bad unknown?. any idea why that lip sticks out at the bottom. I think it is well executed and good looking but whatgood is it?
does my sig work now?
Old 03-16-2012, 06:33 PM   #2 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
the lip i know is used in racing to provide down force in either speed or cornering but not sure for actual mileage
"The only real mistake is the one from which we learn nothing."
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
redorchestra (03-16-2012)
Old 03-16-2012, 06:37 PM   #3 (permalink)
heading for 40
so would make the front of my car act heavier? I don't want heavy, but it does look good doesn't it. great execution
Old 03-16-2012, 06:47 PM   #4 (permalink)
The Dirty330 Modder
Gealii's Avatar
i believe it would make it act heavier do not hold my word to that though, and yea the execution makes it look really nice
- Henry Ford
Old 03-16-2012, 07:54 PM   #5 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
its a splitter. It is used in racing for front down force.
Old 03-16-2012, 08:15 PM   #6 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
If driven at high speed, it will make short work of mowing your yard. Just sayin.
Aerodynamically, it could be a good drag reduction add on as well during the time that it remains attached to the car.
Old 03-16-2012, 09:37 PM   #7 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
The splitter is a bit short, but it should still help to produce some downforce. Look at it this way: As you drive faster, the air pressure at the front of the car becomes greater. The splitter catches that high pressure air and pushes the front of the car down (downforce). The longer the splitter, the better the leverage.
In terms of aerodynamics, it should also help because the farther the front of the car is pushed down, the less air can travel underneath it.
Old 03-16-2012, 09:54 PM   #8 (permalink)
splitter / lip
The lip at the bottom helps to catch air being forced down from the bumper. It directs it around the side of the car rather than letting it go underneath. That keeps you more aero.
Old 03-16-2012, 09:55 PM   #9 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Edit: Ed beat me to it!
It will divert air around the sides of the car instead of it tumbling around the aerodynamically dirty undercarriage. That's good. It should ideally stick down just far enough to shield the chassis and suspension components from oncoming wind, so it looks a little low to me. Perhaps cut an inch or two off the top edge and then install it. This is different for every car, so you'll have to eyeball it to see whether it's sticking down too much or not enough and modify accordingly.
As I understand it, downforce doesn't really make the car feel heavier as much as it just gives you more grip. It will increase your overall drag but make the car handle better. If you trim the thing right it will decrease your drag while maintaining basically the same handling. You're probably not going fast enough on the street for the downforce to make much of a difference anyway.
At the end of the day though you could probably get similar looks and the same aerodynamics out of black rubber lawn edging. Check out the Chevy Express van on here which did that and reported noticeable FE improvements.
Old 03-16-2012, 10:01 PM   #10 (permalink)
Team Emperor
The downforce at highway speeds might be significant, though. The amount the front end would dip would probably have more to do with the suspension/spring rates than anything else.
