Old 03-04-2012, 04:57 PM   #21 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
ladogabot,
I can see you doing a clear polycar sheet with rounded corners down the side to follow the lines to the spoiler.
you could have some c shaped hooks that would meet the spoiler from under the sheet.
Use a rearwindow spoiler to anchor it.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 03-04-2012, 05:03 PM   #22 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Yeah, I could definitely do something like that. The 3M double-sided adhesives work really well, also. They might be something that you can use on your project.
Old 03-05-2012, 01:56 PM   #23 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Looks great! Your car was was just made to be Kammbacked.
Originally Posted by mcrews View Post
Do you think I gave up anything by not going the full width of the rear end?
No, you probably even gained a bit. With a boattail you not only want the top to slope down, but also the sides to converge. You wouldn't have a view straight from the rear? A view from above wouldn't be bad either...
The Following User Says Thank You to Piwoslaw For This Useful Post:
skyking (03-06-2012)
Old 03-05-2012, 04:05 PM   #24 (permalink)
Reloadwin's Avatar
Silver Prius - '08 Toyota Prius
90 day: 46.37 mpg (US)
Very interesting keep posting pictures please.
Old 03-06-2012, 01:21 AM   #25 (permalink)
There is the small matter of being able to open the trunk easily. One end of the rear panel needs a hinge and the other needs to slide somehow if it's attached to the trunk.
Old 03-06-2012, 01:29 AM   #26 (permalink)
mcrews's Avatar
Much like a bike rack....it will come off.
THe idea is that the straps crossing and pulling at oposite side will hold it down snugly.
simply reaching in and losing the straps will allow full accress to the trunck.
That's the whole idea.
by triming the edges(that are in contact with the body, with a foam trim, then the kammback will fit snug
ECO MODS PERFORMED:
First: ScangaugeII
Old 03-06-2012, 01:32 AM   #27 (permalink)
mcrews's Avatar
should have taken a picture from the mirror. The view was actually pretty good. It didnt really cut off anything but thr top, I could still see the cars fine. and the side mirrors picked up right where they should.
ECO MODS PERFORMED:
First: ScangaugeII
Old 03-06-2012, 09:55 AM   #28 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I'd think you lost some of its potential by not tapering it in a bit more in planview, and by not lowering the rear as far as you can take it.
The first mock-up pics seem to have the rear a good deal lower than the last (car) photo shows it to be.
Old 03-06-2012, 10:34 AM   #29 (permalink)
mcrews's Avatar
your going to have to be more specific.on the pictures.......
I used the same blue plastic glass each time in the same spot as a space.
As far as the lenght goes, I used a sheet of choroplast that i had lying around. So it was the size that it was. I was actually surprised that the lenght was almost perfect. I have no desire to extend it past the end of the car.
ECO MODS PERFORMED:
First: ScangaugeII
