Old 02-27-2008, 10:57 AM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
What are your 2008 mod goals / wish list?
With the worst of the '07/'08 winter in the rear view mirror, thoughts turn to plans for the return of tinkering weather (for those of us stuck in more northerly lattitudes...)
I'm granting myself some flexibility between "goals" and a "wish list" because I've proven I'm lousy at making & sticking to actual goals on a specific timeline. Even so, I can probably realisticaly divide between attainable vs. hopeful...
So here are my ...
Metro goals:
- properly affix rear skirts (brackets)
- make permanent partial kammback
- experiment with front air dam
- develop front wheel skirts
- test airtabs
Metro wish list:
- lowering
ForkenSwift goals:
- dissassemble, clean & repaint everything (motor, racks, engine compartment)
- install battery pack LED monitor
- add DC/DC converter
ForkenSwift wish list:
- add 2 more batts on a controller bypass circuit for 60v turbo mode
Old 02-27-2008, 11:08 AM   #2 (permalink)
budomove's Avatar
Ze Future Beam - '00 insight
90 day: 66.23 mpg (US)
better rad block
remove front emblem
remove rear wiper
2000 Honda Insight 5spd Silver 63.9 lmpg
Old 02-27-2008, 11:15 AM   #3 (permalink)
OT... but Frank - what's your avatar?
Old 02-27-2008, 11:29 AM   #4 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
crossing my fingers in the hopes that all the the nasties are behind us now.
So here are my ...
Thrifty McGassaver goals:
  • Build a Coroplast Kammeback
  • Finish rebuilding the spare D15Z1
  • Install said rebuilt D15Z1
  • Experiment with front air dam
  • Test out Pulstar Plugs on the D15Z1
  • Purchase and install new suspension
  • Take care of the last little rust spots
  • Refinish my under pan
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 02-27-2008, 12:07 PM   #5 (permalink)
budomove's Avatar
That is a snapshot taken out the rear of my cousins car going over the bayou 10 miles NW of New Orleans.
Old 02-27-2008, 12:11 PM   #6 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Looking out an entire year isn't easy for me. I change my mind way too much.
Matrix Goal: Average tank mileage to 40 mpg
-Improved grill block
-Underbody panel
-Possibly rear wheel skirts
Paseo Goal: Average tank mileage to 55 mpg
-Grill block
-Underbody panel
-Install new reworked head
-New exhaust system
There are many other possibilities that may turn into mods. I'm more into the engine side of it than most. I designed a descent fuel heater that I originally canned since the Matrix already heats its fuel to some degree. However, the Paseo does not so there might be benefits from it. I also just ordered some material for a electrolysis unit for onboard browns gas generation. So, we'll see how that progresses. That'll most likely go on the Matrix. I also have to get my Tercel back on the road. Its going to be a busy summer thats for sure.
Old 02-27-2008, 12:19 PM   #7 (permalink)
Your homework has told you that's not a net loss proposition?
Old 02-27-2008, 12:22 PM   #8 (permalink)
And then is next year's goal rebuilding the "other" spare D15Z1?
Old 02-27-2008, 12:23 PM   #9 (permalink)
CM400E - '81 CM400E
Not when properly designed. The engine doesn't run on the browns gas (hydrogen/oxygen from breaking down water). The browns gas only enhances the combustion event.
When I actually start building and using it you can be sure I'll be posting info.
Old 02-27-2008, 12:53 PM   #10 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
That spoiler. I even have the materials and know I'm going to make/prototype it I even have a modification for it so that my trunk stays usable/accessible
Another goal... My super secret $15 easy to apply belly pan. I've been cooking up this idea for about 6 months now and I think I've finally found a suitable material that's easy to apply, should be easy to remove, weatherproof, can take a bit of heat and is available almost anywhere (in stock in many home improvement stores!). It's also cheaper than coroplast and much lighter - but it's not structural at all. And should it just fall off - it won't hurt anything (just make a bit of a mess as it disintegrates).
I've also been meaning to show off my $1 grille block that's just about perfectly formed to my existing grille and doesn't leave any sticky tape residue
Challenge me, or correct me, but don't ask me to die quietly.
