Old 06-11-2010, 10:06 PM   #31 (permalink)
Porno Music Producer
zhillz's Avatar
lolwut - '98 Civic EX
90 day: 47.5 mpg (US)
How do you get tank average and trip average MPG on your main gauge? I have a newer one with xgauge is it one of those?
Old 06-12-2010, 07:44 PM   #32 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Sedona LX
For my 2000 Cherokee I almost never move it off of:
MPG - instant "right foot conscience"
AVG - this is the "game" number that I'm always working to get as high as possible
MPH - 6% larger tires and the factory speedo has a bit of laziness in it's movements
TPS - used in conjuntion with the instant MPG to get best FE (and control the right foot)
I've found the most important gauge to be the TPS, although sometimes when I can I switch on the LOD instead of MPH to dial it in even more. Since I'm used to the vehicle, I've been able to use the TPS to most accurately put the throtttle where it will work best consistantly to keep FE up.
Old 08-12-2010, 01:25 PM   #33 (permalink)
Cogito Ergo Ecomod
davidgrey50's Avatar
Dobbin - '04 Dakota 3.7 V6 A/T
Just got my SG for my new-to-me 2004 Dakota. It's going to use more gas than the now-retired Focus, but I'm getting better and better at squeezing it down with my new best friend/overseer/benevolent tyrant Scangauge.
LHK - Metric MPG for instant feedback.
AVG
LOD -
CWT - Metric coolant temp.
Old 08-13-2010, 12:09 PM   #34 (permalink)
MPG>HP
Little Blue - '09 Focus SE
Team Ford
90 day: 34.41 mpg (US)
aMPG TPS
iMPG fWT
Best Tank:36.915MPG|422.6Miles
Longest Tank:35.2MPG|435.8Miles
Best Trip:45.9MPG|5.9Miles
Old 08-13-2010, 01:56 PM   #35 (permalink)
kgwedi's Avatar
Metro - '00 Metro
90 day: 55.62 mpg (US)
RV - '97 Leprauchan 29 foot
90 day: 9.26 mpg (US)
MPG Instant MPG Ave
RPM GPH
Old 08-13-2010, 07:07 PM   #36 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...here's my quad:
MPH...AVG
RPM...MPG
Old 08-14-2010, 12:52 AM   #37 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
I do a lot of hgwy and discovered LOD on a long trip. I use to aggressily pass big rigs on the freeway. Now I try to draft a little bitand wait for a larger 'gap' in the fast lane instead of flooring it.........
you can see the effect of the drafting with the load setting.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-14-2010, 12:57 AM   #38 (permalink)
mcrews's Avatar
fyi
I also run a size up on mt tires 255/45/18 instead of 245. I have a Garmin GPS and used the mph function to set the correct mph on the scangaugeII. Actually i swithed both over to metric setting and set it that way. My scangauge is almost always exactly the same as my GPS.
has anyone found the TEMP to be 'off' My car has a 180 degree thermostat and my scangauge runs 197 to 202??
ECO MODS PERFORMED:
First, Grille Block
Stock Temperature Gauges jcantara Instrumentation 24 05-26-2010 11:26 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
Three most useful gauges? JJW Instrumentation 35 10-24-2008 03:31 AM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
What gauges do you use on your scangauge? regor EcoModding Central 12 06-10-2008 10:06 AM
