Old 09-29-2010, 10:30 AM   #1 (permalink)
Tank driver
OD - '05 Econoline
90 day: 14.59 mpg (US)
Camo - '99 Windstar
Team Ford
90 day: 25.22 mpg (US)
Joetta - '86 Jetta Turbo Oil Burner
90 day: 50.35 mpg (US)
What is your favorite settings for your scanner
I just got an ultragauge.
My vehicles have automatic transmissions.
I figure instant fuel economy is probably the number one setting. Keeping the cars in closed loop as well. What other settings do you find important and why?
thanks.
"A man is not finished when he is defeated. He is finished when he quits."
Richard M. Nixon
"The reward of suffering is experience."
Harry S. Truman
Old 09-29-2010, 10:58 AM   #2 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
I like to view my mileage for the tank since fillup. I also display boost and water temperature since I have no gauges in my Beetle. I have a Scangauge, presumably you can get similar outputs with the Ultra.
Old 09-30-2010, 09:46 PM   #3 (permalink)
Tank driver
OD - '05 Econoline
Camo - '99 Windstar
Team Ford
Had my first over the road trip with my OD van (Econoline) today with the Ultragauge.
I tried several settings on page one. Finally decided that the instant economy and trip economy were by far the most important settings. The route was about 150 miles, I averaged 20.8 mpg. The route was hilly. I mounted the gauge below my line of sight. and after a ways I thought that keeping the van above 20mpg was a good goal. At low speeds it was hard to keep it over 10mpg (10-14% grades) but at about 60 it was easy to keep it over 20mpg if fairly flat. Next trip will be flatter and I will try to keep it over 60mph.
When I stopped for gas near my destination there was a gal with a black Prius, I asked her about it and she said that she got 43 mpg. I felt good that I was carrying a van load of stuff and still getting almost 50% of that.
I would say that it won't take me that long to pay for my scanner gauge.
Richard M. Nixon
Harry S. Truman
Old 10-01-2010, 03:05 PM   #4 (permalink)
Niner_xA - '05 xA
90 day: 35.82 mpg (US)
Horse Hauler - '95 F-250 XLT
90 day: 13.47 mpg (US)
Butterkup - '02 Miata
MPGuino here.
I mostly use the instant MPG reading, since it helps me adjust how much lead I've got on the pedal. I also like to switch back to current trip MPG periodically to see the "real world" value that I'm getting (since instant can swing pretty wide and I can't do calculus in my head). Sometimes I also check tank MPG, at least during fillup when I compare with the tank MPG I get from the pump and odometer.
I'm looking at upgrading to an Ultra Gauge. I would like to have engine temperature before I start doing any grill blocks, so I can be more aggressive in the winter and not overheat in the summer.
Old 10-04-2010, 05:51 PM   #5 (permalink)
Tank driver
OD - '05 Econoline
Camo - '99 Windstar
Team Ford
I filled my tank on my Econoline today. I was surprised to note that the Ultra gauge said 19.7mpg I went 256 miles and put in 14.7 gallons giving me 17.4mpg. It amounted to 1.7 gallons difference or about 13% off.
I didn't fill at the same station each time but I did reset the mpg counter when I filled both times. Still the number seems more off than I would expect. I will be monitoring.
Richard M. Nixon
Harry S. Truman
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
NHW11 pig-tail fixes OBD scanner issue bwilson4web Hybrids 0 06-11-2010 08:45 AM
Autoenginuity scanner bwilson4web Instrumentation 8 05-23-2010 11:10 AM
Graham mini scanner - Quick User's Guide bwilson4web Hybrids 2 11-27-2009 08:58 AM
