Old 07-27-2009, 07:55 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
What're people using for MTF?
Getting a bit of bearing noise out of my transmission. Been thinking about putting GM synchromesh in, but does anyone else have a better idea?
Thanks for all the advice lately
Old 07-27-2009, 08:59 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I went with royal purple in the weight my owner's manual suggested.
Old 07-27-2009, 09:03 PM   #3 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
I went with Valvoline 75W-80, or something like that. I would have liked to get something like Royal Purple, or the syncromesh, but I was on a pretty tight budget. I don't think mine necessarily needed a change, but I definitely noticed a difference shifting after putting the new fluid in.
Changing the fluid to anything should help if there's already a noise, do you know if it's leaking at all?
Old 07-27-2009, 09:44 PM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Synchromesh worked well for me.
Old 07-28-2009, 08:26 AM   #5 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Redline MTL in the Hyundai, VW G52 in the TDI.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 07-28-2009, 09:11 AM   #6 (permalink)
blueflame's Avatar
Moreys additive. Just changing the old oil helps.
Old 07-28-2009, 01:33 PM   #7 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Do you have problems down shifting? Is the noise only when the clutch is depressed or only when is not depressed?
Make sure you know exactly what the problem is. You don't want to put in $42 worth of syn mtx oil and find the problem is something else and you need to drain the trans and buy another $42 of oil.
Otherwise, there is a list....somewhere around here....of the thinest mtx fluids, measured in cintistrokes. I beleive VW's was the thinest.
Old 07-28-2009, 01:56 PM   #8 (permalink)
Moderator
This is what I got from a sticky over at TDIClub.com advising people to stick with vw fluid in their tranny.
Viscosity Comparison @ 100 C
6.3 = OEM G52 (part numbers G052726A2 / G05272601)
10.6 = Redline MTL 70-80
13.8 = Amsoil MTG 75-90
15.2 = Motul Gear 300 75-90
15.6 = Redline MT-90 75-90
15.0 = Elf Tranself Synthese FE 75-90
16.7 = Motul MOTYLGEAR 75-90
Old 07-28-2009, 04:14 PM   #9 (permalink)
Yaris - '07 Yaris Liftback
Red Line ftw
Old 07-28-2009, 07:28 PM   #10 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
I like the Amsoil. Put it in and forget about it.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
I must be losing my mind. Some people need to grow up! Ptero Hypermiling / EcoDriver's Ed 117 06-14-2009 07:48 PM
People Powered Car + Video Matt Herring EcoModding Central 2 12-30-2008 09:58 PM
Some people will never understand EcoModders atomicradish Hypermiling / EcoDriver's Ed 22 07-17-2008 12:23 PM
Can people not do math anymore? adam728 The Lounge 30 06-09-2008 02:45 PM
A drastic change from people born before 1985 compared to people born after 1985... Peakster The Lounge 41 05-30-2008 10:30 AM
