Old 11-26-2011, 04:50 PM   #11 (permalink)
Oil grade
According to my 90' Honda CRX shop manual Honda recommends 10w30 - If you live in an area where the temperature doesn't drop below 0 Fahrenheit you can use 10w40 or 20w40.
Attached is the page from the Manual.
Old 11-26-2011, 08:15 PM   #12 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
Zombie Thread.....ARISE!!
Hey, the 1990 manual page is a cool thing to put in here. I'd say if you have a 1990 car you want to put the 10w-30, or 10w40..Go for it.
I know fer sure my 2004 Honda Owners Manual says use the Honda MTF, but if yer in a pinch, use motor oil, But, Replace the Motor Oil with the Honda Stuff ASAP.
I have been in other Honda specific forums where guys who are veteran mechanics are adamant about using only the Honda MTF oil, it is the only thing I'd ever put in my 04.
Old 11-26-2011, 08:37 PM   #13 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
Honda is a world of its' own. Good advice.
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Old 11-26-2011, 09:29 PM   #14 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
I read somewhere that the motor oil that Honda recommended in 1990 had additives that are no longer in the oil. Basically that means that the old recommendations are no longer valid. Your best bet is the fluid Honda provides for their new manual transmission cars. I can't remember where I read this information since it was two years ago when I sold my VX, but I changed the transmission fluid and used the Honda fluid. It doesn't take much and one of the weaknesses is the input shaft bearings in the Honda transmissions. If you don't have any problems with your transmission then personally I would use the fluid Honda currently recommends.
I learned this lesson the hard way a long time ago when I changed the fluid in a BMW 2002, only to find out later that BMW used mineral oil in their transmissions at the time. Had to replace all the synchros in the transmission, a $600 mistake in 1975, I'll never forget.
regards
Mech
Old 11-27-2011, 01:32 AM   #15 (permalink)
Amsoil
I went ahead and bought 10w30 Synth oil from Amsoil to put in the manual tranny. Anyone see an issue with using this oil? It's what Amsoil recommends for my 90 CRX.
Old 11-28-2011, 12:28 PM   #16 (permalink)
Shorty Small - '90 CRX HF
I think that's a very wise decision. Amsoil makes a great product. I'm curious about and leaning towards this in my 90 CRX HF:
1990 CRX HF
Old 11-28-2011, 08:49 PM   #17 (permalink)
Ladogaboy - '011 Lancer EVO GSR
Team Emperor
90 day: 27.18 mpg (US)
E85 EVO - '011 Lancer EVO GSR
90 day: 21.38 mpg (US)
Just my opinion, but I think Amsoil is over-priced for what you're getting. I'm not going to go so far as to say oil is oil is oil, but the top rated manufacturers are all a safe bet. It just so happens that Amsoil is twice as expensive, and they justify it by saying that their oil will last 5-10x longer.
Old 11-28-2011, 10:23 PM   #18 (permalink)
Wagon - '06 Focus zxw
90 day: 29.69 mpg (US)
2 types of std transmission oil that I like:
gm syncromesh
ford manual transmission fluid (with a steep 31$ a pint)
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
SAAB's (old) freewheeling manual transmission MetroMPG General Efficiency Discussion 1 01-23-2008 03:32 PM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
transmission determination - how to determine final drive ratio? gwahir EcoModding Central 5 01-11-2008 11:41 PM
