Old 08-12-2010, 06:19 PM   #1 (permalink)
whats the mathmatical forumula for ideal template curve?
Whats the mathematical formula for ideal template curve?
Old 08-12-2010, 06:37 PM   #2 (permalink)
equation for 2.5:1 teardrop
My template is based on a Zeppelin airship,teardrop form,with a length to diameter ratio of 2.5:1.
Teardrops as short as 2.1:1 have the same Cd,but if you use them for a template,out at 80% aft-body they violate Mair's maximum boat tail tangent angle of 22-degrees.
The 2.5:1 'body-of-revolution was the 'shortest' teardrop I could come up with that maintained the 22-degree angle limit at 80% of potentially useful length.Teardrops with greater fineness ratios will begin to accrue additional drag due to increased skin-friction from the additional wetted area.
Someone with a calculus background could probably help write the equation for the curvature.
'Apology for the rough graphic of the template.At larger scale,a french curve could be used for curve smoothing to take the 'bumps' out.
Old 08-12-2010, 09:08 PM   #3 (permalink)
I wanted to know
1 curiosity
2 to get better resolution
3 If i build a boattail with 4 or curving 6 sides the edges im going to have to cut is going to be the template curve multiplied by the template curve.
Old 08-13-2010, 01:29 PM   #4 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Insight
90 day: 98.7 mpg (US)
.... Someone with a calculus background could probably help write the equation for the curvature.
'Apology for the rough graphic of the template.At larger scale,a french curve could be used for curve smoothing to take the 'bumps' out.....
I think that the curve could be curve could be duplicated by developing a polynomial curve fit.
It would take a little doing up-front to 'prepare' the data by developing a curve that has a gradually increasing radius, and build a data set for generating the polynomial coefficients.
Maybe someone with fresh calculus background can do it faster, but I'm reasonably sure it can be done by other means as well.
Jim.
flow separation:Tiger Woods meets Cinderella,or 5-seconds to a perfect roofline aerohead Aerodynamics 39 02-03-2010 04:53 PM
