02-11-2015, 08:23 AM
Fiesta - '06 Ford Fiesta 1.4 Ambiante 90 day: 45.9 mpg (US) Dakar - '03 BMW f650 GS Dakar (retired) Tucson - '07 Hyundai Tucson 2.0 GLS 90 day: 32.67 mpg (US)
Whats your best ecomod?
whats your best single ecomod that gave you the biggest gain in FE? I havnt started modifying my car yet still collecting data on standard car before I start the mods. However just changing my driving style only so far have saved me around 1.5l per 100km or around 9mpg. but want to know what single mod will give me the biggest gain further. personally I think it would be a grill block but what were your results?
02-11-2015, 08:26 AM
Not bad for a machine
Kill-Switch
runner up is my Scangauge.
The Following 3 Users Say Thank You to dirtydave For This Useful Post:
02-11-2015, 08:28 AM
my car got power steering that I loose when engine is off. how exactly does the scangauge save you?
02-11-2015, 08:39 AM
Because I can look at all kinds of data as I am driving!!
Instant MPG, Average MPG, I can look at my foot with the throttle position sensor gauge, I can look at the LOD or load the engine is at, MAP sensor, how much horse power I am using. $ per mile, The Air intake temperature, Water temp, clears and reads check engine lights. Once you get it you are shocked how you lived without it.
If you are broke get a OBD2 ELM bluetooth dongle a cheap android phone and a few apps that do the same thing as the scangauge.
The Following 5 Users Say Thank You to dirtydave For This Useful Post:
02-11-2015, 09:26 AM
Lean Burn Cruiser!
I'm 100% with dirtydave on the Scangauge. Being able to see instant data readout is crucial. That data allows you to modify your driving style to greater extent on the fly.
Case in point, my ZX2 was cruising yesterday at the same speed, but dependent upon my throttle, getting between 37 and 43 mpg. Being able to see that I am getting 43 instead of 37 adds up quick.
The Following 3 Users Say Thank You to BabyDiesel For This Useful Post:
02-11-2015, 10:22 AM
Hypermiler
Scangauge. Knowledge is power. For instance, knowing that a single red light knocks several mpg off your trip average, you do all you can to time the light and roll through on green.
The Following 4 Users Say Thank You to PaleMelanesian For This Useful Post:
02-11-2015, 11:45 AM
MPGuino - definitely!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
02-11-2015, 11:51 AM
Rat Racer
Originally Posted by PaleMelanesian
Knowledge is power.
None of the other mods can to a proper job if you can't see what thry're doing.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 6 Users Say Thank You to Fat Charlie For This Useful Post:
02-11-2015, 12:39 PM
#9 (permalink)
herp derp Apprentice
Scangauge lets me know my airdam has made the biggest improvement when cruising at a steady speed, and that the rear wheel skirts I tried actually hurt mileage.(although I want to retest them with tire spats on, and something to help separation at the back corners, currently thinking the smoother air from the skirts follows the drag inducing large radius bumper corners) I would have just assumed they helped if not tested
The Following User Says Thank You to 2000mc For This Useful Post:
02-11-2015, 12:55 PM
#10 (permalink)
No doubt in my mind.
My best mod was slowing down the engine at any given road speed through re-gearing. Done in two stages. First 3.08:1 rear axle gear, then a GV overdrive. Good for a 20% improvement by itself and also make it easier to realize aero road load reductions.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following 3 Users Say Thank You to Big Dave For This Useful Post:
