Old 07-12-2009, 08:51 PM   #31 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Christ -
Originally Posted by Christ View Post
I understand, I understand, and you can use any heat source, as long as it can get you to 240* or so and hold there for a few mins. (Grill?)
I have a heat gun and the pizza pan has holes in it, so I could blast it from below. Maybe put a metal pan in between to help "even" the temp distribution(?!?!?). I could vary the overall temp as a function of distance between the heat gun and the pan.
Lots of good fabbing ideas flying around.
CarloSW2
American Solar Energy Society
Old 07-12-2009, 09:51 PM   #32 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Originally Posted by cfg83 View Post
Christ -
CarloSW2
Got an insulated box that you can put the pizza pan in? You can spray the heat gun into it and watch the internal temp until it gets to a good temp, then just let it cool for a few hours. It should form anyway.
Another thing that you could use instead of PVA is ABS... but I'm not sure about the melting point (before it burns). I do know that you can melt ABS in acetone, and use it for patch plastic. Maybe you could try forming some by soaking it in acetone and pressing it into a mold?
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 07-21-2009, 12:40 AM   #33 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
The wheel covers are pretty sturdy after a week :
Wheel Cover Report I
To solve the "small valve stem access hole" problem I made a "magnetic" valve stem cover out of a valve stem that can be removed with a 3/8 socket. The socket is metal and the valve stem cover is magnetic, so it stays in the socket after I unscrew it.
I will be making the "donut version" next for the rear wheel.
CarloSW2
Old 07-21-2009, 12:42 AM   #34 (permalink)
Steve - '92 Festiva
Great!
As far as improvements, doing the metal work thing actually makes a sort of shallow parabola, which is geometrically self-sustaining. It needs no further bracing, other than the stiffness of the material you use.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-15-2009 11:55 PM
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 07:54 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
