Old 07-15-2008, 09:13 PM   #11 (permalink)
Miata - '93 Miata
90 day: 34.79 mpg (US)
I think you have stock 97' 14" steel wheels at about 18lbs.
If the 93' is a 13" wheel it should be around 16lbs.
$75 if you sounds good if you want the tires. The 2lb savings is just a little plus but shouldn't be the main reason to buy these wheels.
My Miata came with 12.3lbs wheels but are a bit ugly.
Table of Wheel Weights
Old 07-17-2008, 04:25 PM   #12 (permalink)
Nice Timing - '97 Civic DX
90 day: 38.83 mpg (US)
Thanks for all the advice. If I end up buying them it'll be just to have another set of decent tires for cheap. My current tires have a good amount of thread left on them. I might just buy these and slap them on until they run out. But I might have sold this car by then.
Honda Insight Wheels Ryland Hybrids 24 04-20-2011 12:45 PM
Civic VX wheels or aftermarket? travr6 EcoModding Central 8 03-07-2010 06:37 PM
Lugs for 12" studs that work for 13" wheels? SirKeats EcoModding Central 5 06-05-2008 01:48 PM
Civic with noisy wheels Twerp Off-Topic Tech 9 05-30-2008 11:22 AM
What does YOUR bike weigh? AndrewJ Alternative Transportation 20 01-08-2008 09:56 PM
