Old 10-04-2009, 08:17 PM   #1 (permalink)
pstrbrc's Avatar
where can I find a coast-down spreadsheet?
OK, back in the old days (yes, I'm old. I remember slide rules and FORTRAN and the excitement of a Texas Instruments SR-51. In fact, I think I might still have mine.) I remember there were calculations based on timing coast downs that would allow you to calculate both rolling resistance and aero resistance. I've seen mention of that being done by Excel spreadsheet (ain't computers wunnerful?) and am wondering if there is a spreadsheet readily available since my brain hasn't done that kind of physics calculation for, well, a long time. Anybody?
Old 10-04-2009, 10:19 PM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
This page has a spreadsheet for determining Cd:
Equipment
Or, you could use it for the RR if you know the Cd -- you need one to get the other, unfortunately.
Old 10-05-2009, 12:49 AM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Here's another one:
Coastdown.
Piwoslaw's Peugeot 307sw modding thread
Old 10-05-2009, 05:44 AM   #4 (permalink)
1. Since rr is assumed to be constant W/R/T velocity, what about pushing/pulling car, on a level paved surface, with a scale to show force? (Ex: rope tied to bumper, to scale, rope to puller). Note that the "breakaway" force to get the car rolling WILL be higher than that to KEEP it rolling...the latter is what you want.
2. The "coastdown" method requires a. a flat road for >= 1mi and b. no traffic/police presence. Since these (esp. a.) are infrequent where I am, what about terminal velocity on a gradient of known %? The benefit is both that roads are engineered to have constant grades, and that the 4-6% highway standards will produce quasi-legal terminal velocities for most cars...drawing a lot less attention.
3. Using rho (~1.22 in SI units): Air pressure is 29.92 " Hg at S/L and drops about 1"/1,000 ft. This rule of thumb is good to at least 8,000'...so, 99.44% of motoring roads. So, find rho for your temp, and knock off 1/30th for each 1,000' above S/L.
EDIT: Just wanted to add I gave this a try...just a 0.3 mi stretch with constant (slight) grade. T.V. in four runs was: 66, 65, 64, 65. I also verified 60 was too low (+1.5 MPH) and 70 was too high (-2.0 MPH). Worked fine--very consistent!
Now all I need to do is get out there with a carpenter level and calculate grade, and I'll know how many # thrust it takes to maintain 65 (corrected for wind...)
Coast down test methods and determining cD? wwkayaker Aerodynamics 11 10-29-2009 01:53 AM
Algae Fuel Coast To Coast Run Matt Herring Fossil Fuel Free 8 09-02-2009 05:13 PM
success : pulse and coast in neutral at mid speed (40-55 mph) groar Success Stories 10 04-11-2009 07:26 PM
How long/far to coast? ScottC33 Hypermiling / EcoDriver's Ed 11 07-30-2008 05:05 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
