Old 10-05-2008, 03:02 PM   #21 (permalink)
Red Beast - '82 V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Neon SXT
90 day: 28.71 mpg (US)
Corplast will be VERY available (Free even) on November 5, 2008, at nearly every street corner in USA.
Old 10-05-2008, 05:44 PM   #22 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Here's the trick to cleaning the lettering from Coroplast:
Acetone or lacquer thinner will quickly melt most ink, but if you let the solvent evaporate, you just have a different mess. Immediate towel drying is the key. You can use two hands, one with a wet rag, followed immediately by a dry one as you scrub across a section in broad zig-zags. For smaller jobs, just take a paper towel, fold it a bit, and hold it on your hand by gripping between your fingers. Wet the edge at the heel of your hand, and use the finger side for drying. You just rub the spot you want to clean with the wet towel, and do hand-waving motions from the elbow while slowly progressing across the surface.
BTW, this is a useful skill for anyone who uses solvents to prepare surfaces for bonding. The commercial grades usually leave some oil behind if allowed to evaporate, even if there was none there before.
Old 10-05-2008, 11:03 PM   #23 (permalink)
I would have just painted over it. But nice tip!
Old 11-10-2009, 04:59 PM   #24 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
I picked up enough to do the grill blocks, wheel skirts, and undersides of both my cars, the morning of Nov. 4th. I drove out on a country road and helped the different campaign staffers for both parties with their sign removal cleanups.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 11-10-2009, 05:39 PM   #25 (permalink)
Draco - '89 F150 ext cab shrt bed XLT Lariat
90 day: 16.45 mpg (US)
The spot advertising agency in York, PA 5' X 10' sheet = $20 picked up.
Old 11-11-2009, 01:59 AM   #26 (permalink)
Plascore - Honeycomb Cores - Composite Boards
it comes in a LOT of cool flavors....
Dave
If it has a motor its worth playing with.......
Old 11-16-2009, 04:46 PM   #27 (permalink)
darcane's Avatar
Silverado - '03 Silverado W/T
Pickups
90 day: 18.7 mpg (US)
Ninja 650R - '06 Ninja 650R
90 day: 52.02 mpg (US)
I just bought several sheets from Calsak Plastics - Plastic Materials, ABS Plastic, Plexiglass (Plexiglas), Acrylic Plastic, PVC for $16 for a 4x8.
They have offices in several major west coast cities as well as Atlanta and Houston.
Mike
2003 Silverado:
Aero Mods
Old 11-17-2009, 07:43 PM   #28 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
I found some white for less than $14 per 4x8 sheet, and colors for less than $17.
I looked up a few sign shops and asked about where they got their Coroplast. This should work in most metro areas.
Old 11-18-2009, 01:12 AM   #29 (permalink)
darcane's Avatar
Pickups
I did that too, but most places I called were wholesale only. That's fine if you buy a thousand sheets, not so great if you buy three. But I eventually got to the right place.
2003 Silverado:
Aero Mods
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
crx coroplast belly pan finished! paulwelkins EcoModding Central 25 06-13-2009 01:14 PM
