Old 04-04-2010, 12:47 AM   #31 (permalink)
update:
I'm a couple of basic mods in and more than happy with my results so far. air dam=3 mpg increase(alot of variables though-increase in temp+ introduction of fuel injector cleaner lc fp plus) from 40-42 average mpg. injector cleaner btw, more than happy with. less cranking and i still swear by a smoother idle. it is possible that i'm just hoping that it is smoother in comparison, either way less cranking is better on the electrical and starter.
air dam + 80% grille block = 47.8 mpg average over 2 tanks with no regard to speed. i got caught several times leaving late for work and driving 75mph on a 20 mile commute. I assume mpg would have been better doing 60-65.
New weather stripping on the hood and side skirts extending to a clearance of 3 inches are next followed/accompanied by rear wheel skirts. My goal is 50 mpg!
i cant stop bragging to my buddies that my 214,000 mile 94 civic is still running, and better than new w/ engine compression still at the stock 180 psi range. i'm going on my 3rd timing belt this week! w/ that out of the way, I know its just a matter of time before i have engine/transmission issues. as clark howard preaches: drive it until the wheels fall off.
My front struts only are however starting to go. If i were to replace them with a lowered set would i be able to see any return in mpg? It would be an aggressive angle and i'm curious how handling would be affected if the rear is left untouched to save money. stock struts/springs are the default fix no return is expected.
Old 04-04-2010, 10:42 AM   #32 (permalink)
laack, those are good # for air dam and grill block,
I agree, keep up with the major maint and keep her driving, I have an 00 accord v6 with 200k that we just did the major service, the car drives like new
tranny is the only weak spot, take care of it and you will be golden,
with the tires being at max, you will have a horrid ride with old springs and shocks, just get a progressive lowering spring and some econ shocks, while at it, get a new PU link kit and do that too.
Q: how did ya attach the air dam?
DIY: Push Button Start SVOboy DIY / How-to 16 11-15-2011 01:10 PM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 75 05-24-2011 02:34 PM
Electric Vehicle Information - Start Here bennelson Fossil Fuel Free 9 05-08-2010 04:18 PM
start a "Fire" fly EV project Trevs Introductions 16 04-30-2010 09:00 PM
Car Won't Start While Moving in Neutral Any Ideas? Axaday EcoModding Central 3 06-29-2008 11:26 PM
