White Lightning - 2005 Focus Build
So Little Red got laid to rest after deer hunting, and now
White Lightning is to replace it, I am looking to do pizza pan wheel covers and change the tires to one size taller after these wear out, I am also gonna do a grille block and some extra lights, this car has power locks and windows, cruise, tilt/slide steering wheel, as to where the last focus had manual everything, and all the options work....bonus!!!:D |
All ideas will be greatly appreciated
And I found that this vehicle uses PWM for TCC lockup and I am not going to go into that! |
Well, I don't know exactly why this landed in the Unicorn Corral. Looks like a nice enough car and if the pictures are any evidence, it actually exists.
Why is this here? |
Probably where I started...lol
Yeah, and misleading title. I thought it was going to be about building a still to make your own ethanol fuel :-)
And that wouldn't have been a unicorn either, since under the right circumstances distilling your own ethanol for fuel has been the most economical choice in the past and may be again in the future.
A PWM for TCC from what I have read is used to softly engage converter lockup.
Congrats on the new wheels. I look forward to seeing what you can do with it!
Do not fear electronics! Learn it and a whole new world will open up to you. :) |
Still slowly working on my car and making it more efficient, hard to get results right now because the weather has been all over the place, but I did redneckify a lower engine cover from a 2012 focus to fit my car.
Is there a way to put this in the Aerodynamics threads instead of unicorns?
