Old 10-11-2008, 04:51 PM   #1 (permalink)
Oden - '00 Frontier Crew Cab
Pickups
90 day: 21.99 mpg (US)
Malinda(WJ) - '03 Grand Cherokee Limited
90 day: 15.28 mpg (US)
Nerdcycle - '81 CM400E
Motorcycle
90 day: 53.8 mpg (US)
Bumblebee - '08 V3
Motorcycle
90 day: 69.17 mpg (US)
Why does the heater core transfer heat from the coolant, not the exhaust?
It would be hot almost instantly and would allow for an air cooled engine whose temperature could be controlled precisely by the amount of air that was let into the engine compartment.
The only reason I can think of is that it would be TOO hot, but that can be solved by just placing less heat exchange material on the pipe. It's probably be just fine to run the regular pipe through the airstream.
Old 10-11-2008, 05:02 PM   #2 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Too complicated is my best guess...
Old 10-11-2008, 05:30 PM   #3 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
If it leaks, it's poisonous gas leaking in the cabin versus engine coolant
That, and it's a whole lot easier to route a relatively clean liquid than a much hotter gas
Challenge me, or correct me, but don't ask me to die quietly.
Old 10-11-2008, 06:17 PM   #4 (permalink)
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.57 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
trebuchet hit the nail on the head....toxic fume leaks.
Old 10-11-2008, 06:28 PM   #5 (permalink)
Why don't they run an absorption cycle A/C from it?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 10-11-2008, 06:43 PM   #6 (permalink)
MechE
I've been curious of the same thing for a few years now.... But I haven't educated myself enough on the concept to build one myself
Old 10-11-2008, 07:00 PM   #7 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I have a number of vehicles where the cabin heat is gotten from exhaust heat exchangers and/or from cylinder waste heat (VW, Corvair, general aviation aircraft (but I don't own one now)). That system can be great WHEN EVERYTHING IS IN PERFECT WORKING ORDER. But, reality interrupts our little daydream (doesn't it always?). Over time exhaust systems rot out and yes, noxious fumes come into the cabin. Also, when (not if) there is an oil or gasoline leak in or near any component of this sort of heating system, all that stench comes in the cabin too.
Old 10-11-2008, 07:09 PM   #8 (permalink)
Puddles - '95 Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Miata Club Racing
Scooter - '05 Metropolitan
Monstro II - '99 Ram 1500
Kassia - '01 Miata LS
Precious - '97 3500 Silverado Dually
both good answers, I will also add.
-heat is exchanged easier, and more efficiently in a fluid
-antifreeze has an anti corrosive that should ideally keep the system working properly longer
-exhaust is wizzing out of your car as fast as possible, back pressure makes your car perform less goodish, where as the radiator fluid is restricted/slowed down by the therm to make the engine coolant exchange work better, and it doesn't _really_ effect engine performance.
Old 10-11-2008, 07:13 PM   #9 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Fire: I disagree with your points 1 and 3. Experience shows those not to be factors.
Old 10-11-2008, 07:23 PM   #10 (permalink)
That's assuming that you and I agree that VW and Porsche heaters are sufficient. We don't.
Converting Exhaust Heat to Electricity SuperTrooper General Efficiency Discussion 13 03-20-2010 07:03 AM
Waste Heat from Exhaust TES111 EcoModding Central 35 11-21-2008 01:31 PM
Steam engine (from exhaust heat) iHero General Efficiency Discussion 23 09-08-2008 01:30 AM
glow plug based coolant heater Coyote X EcoModding Central 15 01-25-2008 12:09 AM
850 watt tank style coolant heater - installed in the Blackfly MetroMPG EcoModding Central 4 11-28-2007 03:10 PM
