Old 11-09-2008, 11:27 AM   #11 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
That was a typo. Change those GPM to GPH. It was still early in the morning.
aerocivic.com
Old 11-09-2008, 12:31 PM   #12 (permalink)
Cd
Ultimate Fail
Cd's Avatar
My city MPG average is currently between 35 - 37 MPG. I only drive 7 miles one way to work, coast when I can, have memorized the timing of the lights, and hardly EVER use my brakes with more pressure than it takes to crack an egg ... err... an ostrich egg.
My mileage sucks so badly because I am driving an automatic.
On the highway, I have seen over 54 MPG at a steady 55-60 MPH
According to my SuperMID, I loose between 2.5 to as much as 4 MPG when stopping at a light. ( On the instant average readout )
I was just asking the question about braking out of couriousity. Thanks for the feedback.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 11-09-2008, 01:41 PM   #13 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
From 100+ hypermiling / ecodriving tips to increase gas mileage - EcoModder.com
49) Conserve momentum: brake hard
It sounds like a contradiction, but there are rare times when braking hard can save fuel compared to coasting or light braking: it's a "damage control" technique when faced with an unpredictable/unanticipated stop or slow down ahead and not a lot of space.
An example: approaching a fresh red traffic light that had no other indicators to predict the change (no pedestrian signal and no cars waiting on the cross street). If you brake lightly/moderately, you will cover the entire distance to the intersection and have no option but coming to a full stop.
But if you brake quite hard initially, you can potentially scrub enough speed and buy enough time to coast the remaining distance to the intersection at a low speed. With judgment and some luck, you'll arrive at a fresh green light and avoid a full stop.
Obviously, rapid deceleration isn't a safe option if there is following traffic.
Old 11-10-2008, 12:21 AM   #14 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Hey - that's the exception!
Old 11-10-2008, 02:51 AM   #15 (permalink)
On re-reading, I find myself stumbling at the words instant average. Seems like it would be one or the other. Does the manual for the SuperMID give a description of what instant average means?
Old 11-10-2008, 06:37 AM   #16 (permalink)
Interested Newbie
Katana's Avatar
Silver Citroen Saxo - '02 Saxo 1.4i Furio
I do use engine braking a lot, all you do is coast in your current gear or shift to a lower gear and the car slows quicker, you have to be sensible and not shift too low and rev the engine too high.
I asked my father about this as he's a mechanic and he said the engine doesn't use fuel while engine braking on a fuel injection car, since when you coast in gear it turns off the injectors, but the pistons and the other engine stuff is still moving so it still sounds like it's running although quieter.
Are we both wrong?
Crooked toothed, tea swilling crumpet eater!
Old 11-10-2008, 08:31 AM   #17 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
I'm not sure about the SuperMID, but on the cars I've driven that had an instant average, it calculated a rolling average over the last mile, so that the number is fairly accurate, but not jumping around like the instant display.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 11-10-2008, 09:24 AM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
sometimes. In my metro if I coast in top gear above 40mph, it will kill the injectors till it gets down to 35mph, per the mpguino and the butt-meter.
Old 11-10-2008, 11:51 AM   #19 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.88 mpg (US)
Katana, you're describing DFCO; Deceleration Fuel Cut Off. (Let's not miss an opportunity to use an acronym!)
My Vibe does this down to about 1200 RPM. It's a more efficient option to using the brakes.
And yeah, I was trying not to muddy the waters with tip #49.
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 11-10-2008, 12:09 PM   #20 (permalink)
Max - '01 S-10 LS
Also, can you explain engine braking ?
I notice when coasting to a stop I will shift my automatic from neutral back to drive, and the car will shudder and suddenly slow as the engine 'catches ' and revs up.
Is this an example of engine braking ?
That is *NOT* an example of engine braking, it is an example of "how to break a transmission." Any time the car is shuddering, it indicates something is wrong. Some cars take to being shifted in and out of drive while moving, others, like yours, do not. You'll have problems down the line if you continue what you're doing, I guarantee it.
Engine braking involves letting off the throttle. Yes, it's that simple.
Fuel Economy related papers tasdrouille General Efficiency Discussion 31 01-18-2011 11:48 AM
Crashing is real bad for fuel economy SVOboy EcoModding Central 15 06-30-2008 10:59 AM
Lugging the engine - good or bad for economy? landspeed General Efficiency Discussion 27 06-22-2008 09:47 PM
The New York Times: Economy Champs Get the Cold Shoulder akcapeco EcoModding Central 4 06-14-2008 01:42 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
