04-06-2013, 05:51 PM
#11 (permalink)
A bigger # of cylinders have been turned into a premium feature, more than anything. Spending more money for something that would work less efficiently sounds dumb, but many folks are glad to do it...
04-07-2013, 07:43 AM
#12 (permalink)
the crazy guy in back
Cressy - '90 Toyota Cressida Pickup - '91 Toyota Pickup base
Marketing. No matter the displacement, no normal, unintelligent member of the human masses is going to pay for a 2l v8 in their compact car.
And all the technical arguments above: Thermal efficiency, Friction, etc.
-2003 Subaru Baja 2.5 5MT
-2005 Subaru Baja 2.5T 5MT
-1994 Pontiac Firebird 5.7 V8/6MT
-2001 BMW R1200c
-1970 VW Beetle
-2015 Prius (for the wife)
"You don't get to blame me for how I fix what you broke."
04-07-2013, 09:16 AM
#13 (permalink)
Torque=force×distance. If you shorten the stroke and leave force unchanged, you get less torque.
04-07-2013, 12:30 PM
#14 (permalink)
MC SBX - '95 Chevrolet Monte Carlo LS Last 3: 29.75 mpg (US)
you also have less displacement. make up the difference in displacement via a larger bore and torque will be quite similar to what it was before changes. possibly better, since the valves won't be as shrouded.
then there's the whole "a shorter stroke will allow longer rods" argument that comes up in certain circles.
04-07-2013, 05:02 PM
#15 (permalink)
i only know of one instance where a 6 cylinder vs. 4 cylinder is actually benifical.
any 4 cylinder over 2l creates a secondary harmonic, that can distroy engines; harmonic balancers are needed along with heavier crankshafts.
where as the 6 cylinder needs none of that.
gm engines
2.5l I4 110hp; 2.5l v6 145hp; 2.5l I6 154hp
195ci pontiac I4 vs buick 3.0l v6
04-07-2013, 06:56 PM
#16 (permalink)
Lots of Questions
gm engines
Can you explain further the secondary harmonic issue?
Also, on the GM engines, how does the 2.5l V6 and I6 get better HP? That is what I was trying to get at with the original question.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
04-07-2013, 07:04 PM
#17 (permalink)
In 4 cylinder engines of over 2.4 liters the force of the first and last pistons combustion can develop a rocking motion in the engine from front to rear. This is due to the portion of the energy that actually moves the engine block in the opposite direction of the pistons.
I think it was Mitsubishi who developed the countershafts, typically spinning at twice engine speed that counteract that force.
Basically the reason fewer pistons is more efficient, is the physics of the area of a circle.
Pie R squared. The greater the radius the exponentially greater the area.
regards
Mech
04-07-2013, 07:48 PM
#18 (permalink)
gm engines
It's not so much accurate to say a 6cyl would be better just based on horsepower. Look at the 2.4L LE5 engine with its 169hp...
04-07-2013, 08:15 PM
#19 (permalink)
I've heard of tractor engines with one huge cylinder that fires once every four or five seconds, and I bet it produces power rather efficiently, considering the low number of explosions per minute and the very small number of moving parts.
04-07-2013, 08:19 PM
#20 (permalink)
That also leads to another point: the selection of a more efficient gear ratio to deal with the torque pulses
