Old 11-08-2017, 06:25 PM   #1 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
Last 3: 24.65 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 24 AUTO
Pickups
90 day: 22.62 mpg (US)
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
Why thinner oil improves fuel economy
The VI additives have the effect of keeping the oil from thinning excessively when heated. The actual mechanics of this system are a little more complex in that these additives are added to a thinner oil so that it will be fluid at a cold temperature. The VI additives then prevent thinning as the oil is heated so that it now can pass the SAE viscosity rating at 210. For example; if you have a SAE 10 motor oil it will flow like a 10W at the colder temperature. But at 210 degrees it will be a SAE 10 giving us a 10W-10 or SAE 10 viscosity rating. Obviously this is good at cold start up, but terrible at engine operating temperature especially in warmer climates. But by adding the VI additives we can prevent the oil from thinning as it is heated to achieve higher viscosity numbers at 210 degrees. This is how they make a petroleum based motor oil function for the 10W-30 rating. The farther the temperature range, like with a 10W-40, then more VI additives are used. With me so far? Good, now for the bad news.
From Motor Oil Viscosity Grades Explained in Layman's Terms
1st gen cummins 91.5 dodge d250 ,16cm turbo housing ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 29.3mpg 97mi 3.311usg 7/27/16
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 11-08-2017, 08:46 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
I tend to cast a "doubters eye" upon anything that AMZOIL™ spews...
2014 Toyota Prius 1.8L eCVT
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2011 Chevrolet LTZ Cruze 1.4LT 6A
1971 Dodge Charger 318 3A
1970 Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 11-09-2017, 12:56 AM   #3 (permalink)
V8 guy
There waa a post about study Cummins diesel did on thinner oils on here a few years ago.
Going from traditional 15w-40 oil to the thinnest 0w-20 on the market saves about 3%.
But then the valve train wore out in about 2/3 the normal time. So probably not really worth it.
Old 11-09-2017, 02:50 AM   #4 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
As you point out the failur savings are pitiful a penny per thousand miles whereas the extra horsepower required by the oil pump due to higher viscosity can be worth dollars per hundred. Every start is a cold start unless your oil is at operating temp it will take more powerto move the oil , than in a few minutes when completely warmed up. The colder the start the bigger the penalty on a parabolic curve.
Oilpan this point is why you ,I and many others go through such grate lengths to warm the oil in addition to the standerd water heater.
Old tele man
They even admit they are not large oil co. (There still an oil co.).
"As more and more large oil companies switched their "synthetic" motor oils to the less expensive/more profitable Group III (3) base stocks it has become much easier to identify which are PAO based true synthetic. Of the large oil companies, only Mobil 1 Extended Performance, as of this writing (12-16-2012), is still a PAO based true synthetic. The rest, including regular Mobil 1 and Castrol Edge have switched to the cheaper/more profitable Group III (3) petroleum based "synthetic" motor oil. AMSOIL Synthetic Motor Oils are PAO based true synthetic motor oils with the exception of the short oil drain OE and XL synthetic motor oils sold at some Auto Parts Stores and Quick Oil Change Centers.( This sounds like unless you buy direct from supplier even Amsoil is cutting corners as well) This leaves more than 20 PAO based true synthetic motor oils manufactured and marketed by AMSOIL with only a few Group III (3) based synthetic motor oils identified by the "OE" and "XL" product name."
Former
87' Hyundai Excel
Old 11-09-2017, 06:13 AM   #5 (permalink)
Gaptooth - '00 Honda Insight
Gen-1 Insights
90 day: 56.86 mpg (US)
Such Fit - '07 Honda Fit Sport
90 day: 41.27 mpg (US)
For what it's worth, 10k miles on Mobile 1 0w20 in my engine and it was still basically a 0w20; viscosity had not changed measurably. I'm inclined to think that viscosity modifiers, at least in my case, will not break down before other additives are depleted.
Right now I'm running Honda's Green Oil, which is considerably thinner than 0w20. I'll probably have an oil analysis done in a few months for you to look over.
Old 11-09-2017, 08:44 AM   #6 (permalink)
90 day: 39.62 mpg (US)
90 day: 41.67 mpg (US)
I'm gong to have to agree that this is a great reason why pre-warming, or fast warm up solutions are so important. Not just for engine oil, but trans fluid as well.
Current project: Heating the manual trans with engine coolant
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
