Old 10-17-2009, 03:52 AM   #91 (permalink)
I've heard it mentioned indirectly, but the reason tractor-trailers are less draggy per weight is known in aerodynamics as the "square-cube rule."
Imagine you take a Metro and double all its dimensions. The vehicle's volume would have gone up 8X (2^3 for 3-D), but the CdA only goes up 4X (2^2 for 2-D). Thus, it would incur 4X the drag of the stock Metro while carrying 8X the load--half the drag per unit of cargo.
This comes into play a lot in aviation, because weight is 3-D, while lift (proportional to wing area) is 2-D. Because of this, it would be possible to build an airplane that's too damn big to leave the ground! (Allowing for current propulsion systems.)
It would be interesting to see if similar classes of private motor vehicles, (i.e. all sedans) with similar HP/weight ratios, become more efficient per pound of cargo capacity as they get bigger...
Old 10-17-2009, 10:44 AM   #92 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
*did not read whole thread
Diesel is already more fuel efficient. Trucks have a higher load/Cda ratio. Stay at 70mph for nearly all of their trip. Made for hauling, not for city driving or spirited driving. So all of the gear ratios (18 or so of them) are made for highway. They rarely change speeds and they do all of the Hypermiling things because they have to.
Old 10-17-2009, 02:42 PM   #93 (permalink)
surly teady bear
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
Originally Posted by trebuchet03 View Post
Doh! That should have been 140MW - which is
Oh, don't forget the 1450hp APU (you do want a pressurized cabin and hydraulic controls, right?) - which is roughly 1MW...
Good stuff in the rest of the post, The APU is mostly on on the ground, to provide air to start the engines, during takeoff, and approach. In cruse it is off (at least on a 727 and 737, a 747 I don't imagine it would be much different). The cabin pressure comes from bleed air from (I think) one or both of the two inboard engines.
Old 10-18-2009, 02:47 AM   #94 (permalink)
Over the rod trucks use low rolling resistance high pressure skinny tires, proportionally a prius should probably have 2" wide tires... Like my Neighbors 80 year old 40 - 50 MPG Model A. His has a 3 spd tranny and a two speed rear end and if you look the thing over carefully it looks like it has a form of water injection from the radiator. For grins we ran it through DEQ, it had a little more CO than my BMW but everything else was fine.
Dave
Old 10-18-2009, 02:48 AM   #95 (permalink)
I read once that a 747 Engine (one) produces the same KW as a standard Nuclear reactor in the US...
Sounds almost right
Dave
Old 10-18-2009, 02:58 AM   #96 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Tire width is more or less proportional to the weight of the vehicle and the design tire psi.
The old-time cars with skinny tires didn't weigh much.
That, and over time understanding of tire dynamics has improved.
Semi tires aren't 20" wide because they don't spec 30 psi.
Prius would not have 2" wide tires unless they spec'd em with way higher psi than they figure the consumer will accept.
Old 10-18-2009, 03:28 AM   #97 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Originally Posted by slowmover View Post
Have a look at Jay Leno's 1961 FLXIBLE with a 6V-92 Detroit.
The Detroit Series 92 (especially in 6V92TA form) is a favorite of mine in the history of diesel transport. The local Metro bus line replaced old Series-71 equipped GMs with Gilligs in the early 80's. The engine was marketed as a "fuel miser" and was built on the reliability of the previous-gen 71-series. It lacked power, but got the job done. Electronic engine and transmission control improved FE and emissions until the engine was discontinued and replaced by the Series 60, 4-stroke.
Environmentally, the 2-stroke, turbo-aftercooled plant was an emissions nightmare, but served the purpose for the era and offered superior FE compared with older equipment (well into the 90's). Plus there's just something unique about the sound of a 6V-92. Day after day, I heard the passing buses pull a hill from a standing start, which became a familiar routine of "neighborhood sounds" for years.
Anyways, the more gears the better -- 6-speed automatics are becoming more common in cars (borrowing on the torque curve argument)...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 10-18-2009, 03:50 AM   #98 (permalink)
That's kind of what I was alluding to, Design compromise for comfort...
Of course I do drive a jeep wrangler with 4 corner leaf springs, so Its obvious I am numb or like pain...
Dave
Old 10-03-2010, 01:04 AM   #99 (permalink)
mostly harmless
Earl - '86 C10 Silverado
90 day: 11.31 mpg (US)
Herman - '06 HHR 2LT
90 day: 28.91 mpg (US)
A COE (cab-over-engine) has less total surface area. A COE has packaged all components as efficiently as possible.
The best was an early/mid-90's Pete cabover that had a "front" with the slightest V-shape to it. Subtle.
1991 Peterbilt 372
1991 PETERBILT 372 Cabover Truck w/ Sleeper For Sale At TruckPaper.com
I used to own one of these things. Amazingly smooth ride, came from the factory with a Blaupunkt stereo system, and I averaged 9mpg with it, over varied terrain with varied loads. The real killer, and the reason I sold it, had more to do with parts availability from Peterbilt, as they didn't make 'em for long, and quickly declared 'em obsolete.
I kinda miss that ol' truck, though.
Old 10-03-2010, 05:19 AM   #100 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Villager gs
90 day: 19.8 mpg (US)
Max - '98 Maxima SE
90 day: 21.12 mpg (US)
Somehow, I immediatly suspect a exxon mobile buyout of the design, doesn't everyone? Getting 9 mpg in all semi trucks would halve diesel consumption for the US.
BTW nice to see a fellow Arkansan. Where in central AR you at? I have a father in law in Little Rock (actually 2 of them, long story.)
Gotta love wife, kids, and car!
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 03:29 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 10:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 06:31 PM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 03:46 PM
Big Surprise: Fuel efficient cars are holding their value better than other cars SVOboy EcoModder Blog Discussion 2 09-19-2008 09:52 AM
