Old 10-03-2010, 04:49 AM   #101 (permalink)
mostly harmless
Herman - '06 Chevrolet HHR 2LT
90 day: 28.89 mpg (US)
Originally Posted by ShadeTreeMech View Post
Somehow, I immediatly suspect a exxon mobile buyout of the design, doesn't everyone? Getting 9 mpg in all semi trucks would halve diesel consumption for the US.
BTW nice to see a fellow Arkansan. Where in central AR you at? I have a father in law in Little Rock (actually 2 of them, long story.)
I'm in the Little Rock area.
While I think the truck was pretty darned economical, as trucks go, I also tend not to keep the hammer slammed like some guys. I've been getting nearly 6 in the Mack, while the previous driver did about 5.3
Not to brag, but over time, that adds up to quite a bit. Still can't come close to what the Pete did, though.
Old 10-04-2010, 09:46 PM   #102 (permalink)
90 day: 19.36 mpg (US)
Spacer,
Seen the Australian-only (built there) KENWORTH 200? Nicest COE I've ever seen!
Kenworth - Defining Tomorrow: K200
The new Aussie Kenworths! Biglorryblog gets the full story from Mullos and Powertorque! - Biglorryblog
Check out the flat floor.
Thanks for the info about using a 972. I always wondered what a modern 12-liter could do in one of those, especially with a reduced height 48' trailer. An air-ride front axle, as well (read up on a tight cut turn radius one designed for OTR buses a few years ago).
Old 10-04-2010, 10:21 PM   #103 (permalink)
Originally Posted by MadisonMPG View Post
*did not read whole thread
Diesel is already more fuel efficient. Trucks have a higher load/Cda ratio. Stay at 70mph for nearly all of their trip. Made for hauling, not for city driving or spirited driving. So all of the gear ratios (18 or so of them) are made for highway. They rarely change speeds and they do all of the Hypermiling things because they have to.
1] It's actually difficult to stay at 70 without a little too much power (or a lot), but a trip average above 60 isn't bad. (If you get trapped behind a slowmover with overtaking traffic, it may be miles and miles before you can pass and slowly get back to travel speed).
The industry trip plans all miles at 50 mph to account for terrain, traffic, weather, stops, etc. (A number that also works well for cars by the way). A truck near gross weight of 80k is hard to keep up to speed except on the plains and ONLY on the Interstate (or divided, limited-access roadways with bypasses around all towns). A truck down below 60k is fairly easy to keep up to speed (not in the Rockies or West Virginia though).
2] Most big trucks are part of a fleet, thus most transmissions are variations on nine or ten speed. As first gear is a granny, this means -- in use -- 8 or 9 gears for most trucks you see. An 18-speed is pretty well the province of owner-operators who REALLY have a thing for shifting . . you sort of never stop. I think most of us -- if we could spec a truck -- would go for 3.55 rear gears and a 13-speed. Depending on the type of loads carried I'll admit I still want in excess of 500 HP. But never again less than 400 (it's the torque that counts, and less than 1800 LBS/FT makes a long day ahead of 79k. Now, 2000 . . that's a line worth crossing) as a heavy load in hilly/mountainous terrain may mean more than 20-minutes to get up past 60 mph entering the highway. In a speed-governed truck, even longer. The horsepower and the extra few gears would make a great difference. It's all marginal, but it's how one uses that margin.
(TQ tells you if you can make it up the hill . . HP just tells you how fast you'll make it . . and that last 20,000-lbs is the camels back for ease or difficulty in braking and accelerating).
A 10" rest area stop in a car -- from ramp into and ramp out of, and down from 60 to back up to 60 mph -- in a big truck that's laden heavy can be 30" or more. Same exact time out of vehicle (less vehicle inspection).
Power really counts for a driver. Thus the interest in not losing mpg due to terrible aero. Would be great to really get it on at times when needed, believe me. The extra work for the driver is no small matter . . not enough power or gears makes it tough to time the rig to what's happening on the big road.
3] Hypermile? I can't imagine pulse-and-glide in a big truck. Takes years just to learn how to choose the right gear every time. Etc. The one thing that matters is safety and that is full-time. The second is being on time. The rest is hardly considered worthy of attention as a fleet driver. So, if one equates safety with efficiency, then, yes.
Now, if we're limiting our truck driver discussion to cattle-haulers you can forget everything I wrote above.
Old 10-05-2010, 11:35 AM   #104 (permalink)
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Smart Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 BMW V12
90 day: 26.4 mpg (US)
Wildfire 250C - '08 Shandong Pioneer 250C
Aerodynamics has a diminishing impact as weight increases.
Old 10-05-2010, 12:23 PM   #105 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Also, diesel engines are thermally more efficient due to the diesel cycle and higher compression ratio. I just read an article on line about a new non-modified 1.6l VW that traveled 1500 miles on a single tank of fuel (20 gallons), or about 75mpg (average speed 45mph of course).
1,527 Miles On One Tank: Passat Bluemotion Sets New World Record
I'm not coasting, I'm shifting slowly.
Old 10-05-2010, 12:55 PM   #106 (permalink)
Originally Posted by UFO View Post
...a new non-modified 1.6l VW that traveled 1500 miles on a single tank of fuel (20 gallons), or about 75mpg (average speed 45mph of course).
Yeah? Put the same 20 gallon tank in an Insight, and see what you get :-)
Old 10-05-2010, 10:49 PM   #107 (permalink)
Hydrogen Nut
Ptero's Avatar
Yeah? I can haul steel and hay farther than anybody on a single fill-up. Like, from California to Detroit.
Ptero's Pterrible Ptrucking
Old 10-05-2010, 11:04 PM   #108 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
What size tank on the smart?
When I tow I normally see 675-700 mile fillups, 14 gallon ish fill up but I slow down, and have to drop to 5th often.
My normal load is a 1100 lb ZTR on a 4x8 steel trailer with1" deck same vintage as me.
Normal trip is 60 miles each way on 4lane with lots of traffic lights and 65mph speed limit.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 10-05-2010, 11:40 PM   #109 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I DID NOT READ ALL THE POSTS...just to let you know...
My dad used to have a trucking company and ran 21 gears. He knew the gearing inside and out and did his own work. He could get an empty truck up to speed faster than most cars. He knew exactly what gear he wanted to be in and never missed. I used to ride with him in the mountains and we would see spots where trucks had "run away". We would get passed by drivers who thought they could ride the brakes down a mountain and melted them, and yes it looked cool! He averaged 8-9 mpg if I remember right.
A large engine can get very good mileage if it is tuned to put out loads of torque at low rpm. A semi might only have 500 HP but they can have 2,000 ft lbs of torque!!! Once you run that through a tranny, you have WAY more than enough torque to get a load moving.
The thing with I-6 engines is the overlapping power strokes. You can do more at a lower rpm.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 10-06-2010, 11:25 AM   #110 (permalink)
UFO
UFO's Avatar
It won't go far on diesel.
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
Big Surprise: Fuel efficient cars are holding their value better than other cars SVOboy EcoModder Blog Discussion 2 09-19-2008 08:52 AM
