Old 05-16-2008, 08:27 AM   #11 (permalink)
BBsGarage's Avatar
BBsRide - '06 Corolla CE
90 day: 31.64 mpg (US)
I tried my 06 rolla last night and it does start in neutral and no brake.
I didnt try it when moving though.
I know some cars you need to be on the brake as well as 'P' or 'N'
Or it could be that you really were not in neutral.
maybe give it a try at lower speeds with no traffic around.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 05-16-2008, 09:25 AM   #12 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
I tested EOCing my auto 05 Corolla this morning in the parking lot at work and forgot to take it out of drive. I did the quick off-on and the engine was back on immediately. I'll test it again at lunch actually in N.
Old 05-16-2008, 10:02 AM   #13 (permalink)
BBsGarage's Avatar
Where in Jersey are you?
I commute 80 east and 287 north.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 05-16-2008, 12:09 PM   #14 (permalink)
Ex-lurker
Right now I commute Parkway - Rt 3, hopefully soon I'll hear that my commute has moved to 24 - 287. *keepingfingerscrossed*
Old 05-16-2008, 12:22 PM   #15 (permalink)
BBsGarage's Avatar
depending on the direction it may not be much better.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 05-16-2008, 02:12 PM   #16 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
I had the same problem with a Canadian-spec Chrysler 300. It would not start, in Neutral, above a certain speed. I'm not sure if that's a Country-specific safety feature or something. The 300's here don't have that problem...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 05-16-2008, 03:07 PM   #17 (permalink)
Ex-lurker
From what I hear, its a bit slow in the AM but fine later. I'll either find out first hand or it'll be a moot point, but the job would be better.
Old 05-16-2008, 05:45 PM   #18 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
Good ole' old cars not having this problem
It might be what RH77 said. I know the corolla is made in canada.
I think it's a safety thing for the transmission. When you put it back in drive over say, 30mph, the car still thinks it should be started in first gear. so at 55mph it shifts into first gear, instantly knows it's wrong, and engages 4th. This is bad for the transmission. Some cars don't have this problem, but the majority of them do.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 05-16-2008, 09:14 PM   #19 (permalink)
BBsGarage's Avatar
Better jobs are better
Good luck with that.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 75 05-24-2011 02:34 PM
EOC (keep in neutral or 5th gear?) Pillzilla Hypermiling / EcoDriver's Ed 18 08-25-2009 08:58 PM
New York mechanic Andyman Introductions 6 05-13-2008 12:02 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
