Old 08-27-2008, 08:32 AM   #1 (permalink)
Tracy - '00 corsa
will bicycle speedo work as speed sensor for MPGuino?
- i cant find my speed sensor even with the haynes manual.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 08-27-2008, 08:51 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
It sounds noisy I plan on trying it on my old motorcycle eventually though. Another option might be a hall-effect setup or an infrared emitter/detector pair that can sense part of the drivetrain rotating. BUT, it might be a lost in translation thing. Looking at a vauxhall schematic , there are signal abbreviations that I do not recognize, i.e. KSP, IMO, EPS, do you or someone you know know what that means?
Also, B28 and B30 in the below picture appear to be rotation sensors of some sort, but I don't know what:
Old 08-28-2008, 05:55 PM   #3 (permalink)
Tracy - '00 corsa
what signal does the MPGuino look for? the cycle speedo produces a pulse for each revolution. the VSS is not digitized or anything right?
Optimum piston speed? Frank Lee EcoModding Central 73 11-19-2011 04:32 PM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 12:50 AM
Making an electric bicycle (looking for advice) NoCO2 Alternative Transportation 44 06-04-2008 02:54 PM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
Series Motor - Speed vs Torque TomEV Fossil Fuel Free 3 03-02-2008 12:27 PM
