Old 01-08-2009, 10:47 AM   #1 (permalink)
Uncle Jam
GasGuage's Avatar
Lil' Red - '97 S-10 ext 2WD LS
90 day: 31.02 mpg (US)
window film 101
Does anyone out there have experience with tinted glass film? this might be a little off topic for Emods, but on the other hand, keeping the inside cooler would use less A/C thus less fuel. Factory glass has a deep "smoke" look to it. Most aftermarket I seen in parking lots seem to have a "purple" tint to it. Do they come in different colors? I prefer the factory smoke look. Also, which percent(%) tint would look best on rear windows, side, & front glass. Also, what is the legal aspect of this installation? Thanks....
Old 01-08-2009, 03:54 PM   #2 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
The purple is what dealers use (which is originally smoke tint), but becuase it is very low quality it turn purple very fast. All tints turn purple, but good ones will take 10-15 years, cheap one (aka autozone or dealer tint) will turn purple in 1 year.
Old 01-08-2009, 10:07 PM   #3 (permalink)
The Green Hornet - '96 Escort Wagon LX
90 day: 39.26 mpg (US)
The Red Rocket - '96 Metro Base
90 day: 53.07 mpg (US)
The other thing that turns tint purple is using glass cleaner with ammonia in it. But generally, it is lower quality tint that uses dye for the tint, as opposed to a true manufactured tint.
All states have different laws regarding tint.
Old 01-09-2009, 10:00 AM   #4 (permalink)
Uncle Jam
GasGuage's Avatar
Where can you buy a good, quality tint?
Old 01-09-2009, 02:38 PM   #5 (permalink)
If you have never done tint before, I don't recommend trying it yourself. It is a bit of am art. I have had good success with two different precut tint sellers off eBay. Do your homework, but don't try it as a first time installer.
Old 01-09-2009, 02:54 PM   #6 (permalink)
Misanthropologist
captainslug's Avatar
BORK! - '89 240 DL Wagon
90 day: 21.27 mpg (US)
Assuming you have experience with dissecting the doors in order to remove the glass (requires having the maintenance manual handy), applying tint is fairly easy. You just submerge the glass and tint in soapy water, remove the backing from the tint, apply it to the glass, smooth out the bubbles, and remove the completed piece from the tub to let it dry.
You then trim the excess.
The soapy water retards the adhesive on the tinting film, allowing you to shift it around to remove the air bubbles.
Old 01-09-2009, 02:56 PM   #7 (permalink)
I'd agree that the tinting does reduce the temp inside the car. Having owned both tinted and non-tinted cars the one with the tinted windows was always a little cooler in the summer. However, backing up at night usually meant rolling down the windows to see the mirrors (but a good hypermiler shouldn't be backing up anyways)
As for the tint jobs, I wouldn't do it myself just cause I see TONS of cars with hundreds of bubbles in their tint jobs...especially the back windows. I'd guess that if they had a shop do that it'd be covered under warranty so it probably is only DIY ones that end up that way...at least that's my guess.
Old 01-09-2009, 05:33 PM   #8 (permalink)
That is a WAY simplified process, and not exactly practical to do for the back window or rear quarter windows, don't you think?
And todays compound curved windows - that method definitely will not work.
No professional tint shops do it that way, and for a reason.
Did you come up with this idea, or have you seen/done it that way before - I'm curious to know?
Old 01-09-2009, 11:06 PM   #9 (permalink)
ETST/Mazda3
I have used the diy window tint from WM/auto parts store, it depends upon the brand, etc., as whether it will turn purple soon. Mine did not turn purple, I did not use the cheapest nor the most expensive. The task itself is not that hard, but tedious and time consuming if you want it to look good (no bubbles, etc), You have to think about what you are doing, you can cut a pattern for each window (just reverse it for the other side of the vehicle) from heavy paper/poster board, etc if you want, measure w/ a tape measure, cut out a rough size piece of film, and then trim to fit, then take it off, clean the inside of the window several times, then put the film on, and work the bubbles out. Hope you don't get a piece of lint inbetween the glass/film as well as it will look like a bubble. You can buy the rubber squeegee when you buy the film, again, not hard, but not easy either. If you have a pick up, the back window is a good place to start, its flat, easy shape to try amd see if you like your handywork. Don't admire your work long in the sun, as if you let the glue dry, its a #$%^& to get off, (think razor blades and tint off solution) and a big mess, the interior will be wet from numerous wettings of the glue to dissolve it, etc. If your vehicle is still in good shape and you're still proud of it by washing/waxing it regularly, would suggest you have it done, if its a beat up daily driver, and want to try it , go for it, but figure a weekend easy.
Old 01-09-2009, 11:34 PM   #10 (permalink)
I'm from East Tn as well, jimp. Where are you at?
Reviving a 2000 Honda Insight "beater" Red Hybrids 201 01-06-2012 12:42 AM
Solar film - could it help power a vehicle? Serafina_tikklya Fossil Fuel Free 21 12-01-2008 02:12 PM
Window down? JQmile Aerodynamics 1 11-02-2008 12:51 PM
Reduce A/C load by tinting your house windows! darkdan Saving@Home 7 07-08-2008 10:23 AM
tuft testing on 93 Sentra back window jim-frank Aerodynamics 5 06-16-2008 05:59 PM
