Old 08-11-2010, 04:59 AM   #31 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Originally Posted by darkdan View Post
Europe is about the only place that still has decent prices for tint (from a tinter's perspective). It's not just a product, but it's a service so the skill of the installer is important.
Skill certainly is important, and you pay for skilled labour, but that's a bit excessive IMO.
Even the Volvo sunshades aren't that expensive
(They are rather effective, and even look like window tint from a distance, but they add more weight)
But DIY tint always looks horrible. Don't take your classy car (I've always wanted a V50) and ruin it's appearance with a DIY job.
Don't worry, I like its looks too, so I don't plan on ruining them
If I'm not happy with the result, it'll come off faster than it has gone on
Lifetime fuel consumption :
Old 08-11-2010, 10:01 AM   #32 (permalink)
Half Pint - '09 Rio SX
90 day: 44.81 mpg (US)
darkdan, I absolutely agree. I did a DIY job of installing tint on a station wagon I had years ago and found it was not my forte. It looked terrible. A professional job (IMHO) is cheaper than the frustration / aggravation of a job poorly done by me. I've always maintained that I'd rather be mad about the price than the quality.
Old 08-11-2010, 10:05 AM   #33 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
+1 from here too.
Old 08-11-2010, 10:28 AM   #34 (permalink)
Window Tinting Pimp
Originally Posted by roflwaffle View Post
That depends on the car. W/ older models that's usually the case, and in order to reduce the cooling people will turn up the temperature, which just mixes the cool air w/ warmer air. On newer vehicles, the cool air tends to be stored and gradually let out so the AC compressor can cycle on and off depending on the temperature the occupants want, so for newer cars it can help w/ gas mileage.
I wasn't aware any cars cycled the compressor (except maybe the ones that you set a temperature).
Old 08-12-2010, 06:53 PM   #35 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Most build within the last ~5-10 years (give or take) do so AFAIK. It's really obvious at idle on w/ early 8th gen Corollas for instance. You can watch the idle speed move around as the AC compressor cycles on/off and can hear some sort of vacuum operated passageway open up when the temp gets high enough. Newer cars are probably a lot more refined in terms of engagement, but it's pretty much run of the mill now.
Old 08-13-2010, 12:54 AM   #36 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
Darkdan,
Wow.......we've been schooled!!!!!!
thanks a bunch. Nice presentation!!!
:thum bup:: thumbup::thumb up:
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-14-2010, 10:27 AM   #37 (permalink)
Window Tinting Pimp
Thanks! I appreciate it.
Tinted my new focus with Geoshield ceramic 50%:
Rolling on 15s son!
50% is the legal limit in MN.
My scangauge came in the mail yesterday (wow, ordered it Tuesday from ecomodder.com and it arrived Friday, can't beat that). I mounted it on the steering wheel column because I'm not creative.
Old 08-15-2010, 01:43 AM   #38 (permalink)
mcrews's Avatar
my sg actually sits on the clear plasitc in front of the gauges. I use the sg MPH function because my speedo is off due to tire size. Also, after a while u realize you are looking away from your normal field if the sg is not dead in front of you.
ECO MODS PERFORMED:
First, Grille Block
Old 09-07-2010, 05:07 PM   #39 (permalink)
Tinting my windows seemed to really reduce residual head inside my car.
Cheap DIY Solar window tint bennelson Saving@Home 9 05-11-2012 10:16 AM
Reviving a 2000 Honda Insight "beater" Red Hybrids 209 05-07-2012 09:47 AM
Window "tint" saves fuel through reduced AC load (duh, but nice to see quantified) MetroMPG General Efficiency Discussion 31 10-13-2010 01:51 PM
tuft testing on 93 Sentra back window jim-frank Aerodynamics 5 06-16-2008 04:59 PM
Window tint dremd EcoModding Central 4 04-27-2008 11:12 AM
