Old 02-12-2009, 03:37 PM   #11 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
I'd have to disagree, I don't think its debatable.
#1) They increase frontal area which inherantly increases drag.
#2) There is no way they don't cause separation. Its an edge hanging out from the car a good inch. Without it, there is at least has a chance for the flow to stay attached.
And hence the debate
1)I am not arguing that they don't increase frontal area
2)I am not arguing that they don't cause separation... rather that they COULD keep air flow attached to the point that it's parallel with the car instead of it separating at an angle away from the car. IN THEORY this COULD reduce the Cd of the car. If they are completely contained in a region of separation they will have little or no effect. The only way they hurt the car's Cd would be if there is really no region of separation.
This being said, I would guess that if you were able to do coast down testing the Cd would not vary enough for you to notice.
Old 02-13-2009, 06:51 PM   #12 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 20.27 mpg (US)
I removed the rear ones because they are never used, and as far as I could tell they were only acting like parachutes.
As for the front, I was plowing down the freeway last weekend and I found that after reaching out and breaking the seal only on the backmost edge of the deflector (down the B-pillar) drastically reduced air noise. Think about it... they act like parachutes at the rear end also. Popping the back end loose lets the any air trapped in them flow right through.
Old 02-14-2009, 01:23 PM   #13 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 17.6 mpg (US)
Heep - '011 Grand cherokee Larado x 4x4
90 day: 19.92 mpg (US)
Old toy - '81 Cm400e
Da bike - '06 Shadow Vlx deluxe
90 day: 50.18 mpg (US)
i have in channels on my 09. u cant see them fron the front. if they stick out 1/4 of an inch it would be alot. i dont think that style would hurt as much.
pic. click it they grey one.
http://www.customtacos.com/gallery2/...0/IMG_2667.JPG
also the whire one, has NOT been driven off-road. that is all 2 lanes paved roads to work and back.
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 02-14-2009, 01:57 PM   #14 (permalink)
Maybe you should cut out the rear edge that acts like a parachute?
Old 02-14-2009, 02:19 PM   #15 (permalink)
Originally Posted by sepp View Post
ive been wondering about this to, but apparently they are only advertised as weather deflectors. and never for any aerodynamic gain, wich they certainly would do if there was any.
but i noticed that all modern trucks have these wind guides to the sides of their cabs, to help keep the airstream attached.
why not place such guides on all the edges of our cars where the airsteam detaches? like above the nose, above the windshield, around the A-beams... would that do any good?
Anyone with more info on the above, as i have bee looking at these lately
Old 02-14-2009, 04:14 PM   #16 (permalink)
vent visors
My only thought is that during summer operation,the partially open windows might allow you to dispense with the air-conditioning,using fresh air and blower only, for a little savings.------------- For the rest of the year,the visors,as others have already mentioned,cost you in an increased drag penalty.Since they have not been included in the highest mpg cars offered,we can take that as a clue as to their value in an energy savings context.
Reviving a 2000 Honda Insight "beater" Red Hybrids 209 05-07-2012 09:47 AM
Window down? JQmile Aerodynamics 1 11-02-2008 11:51 AM
Neat gadget: Solar Auto Vent Daox EcoModding Central 2 10-14-2008 10:28 AM
tuft testing on 93 Sentra back window jim-frank Aerodynamics 5 06-16-2008 04:59 PM
When does having your windows down start to effect your mileage? Chris D. Aerodynamics 9 03-11-2008 12:15 AM
