Old 10-31-2008, 05:56 PM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Winning entries in Infineon "Rev up fuel efficiency" design competition
Via: Rev Up Fuel Efficiency Design Contest - Engineering TV
Too bad ecomodders didn't know about this in advance!
Infineon and Auto Electronics magazine sponsored the Rev Up Fuel Efficiency Design Contest, where engineers took the "green challenge" to design a solution using Infineon products that enables or improves energy efficiency for automotive applications. The goal: increase the car fleet fuel efficiency from today's 26.6 mpg to 35 mpg by 2012.
1st place:
The Smart Driving Manager
Submitted by Kahmin Teh
Provides real-time data to dramatically reduce engine idle time and braking losses in urban driving
The Smart Driving Manager utilizes signals from stoplights and other traffic sensors to provide real-time information to allow drivers to determine when to completely stop the engine, as well as how to control driving patterns. This allows the driver to control the amount of time the engine is idling wastefully, reducing urban fuel consumption dramatically.
(A variation on a system Audi has been talking about: Audi's Green light Computer )
2nd place:
Exhaust gas electrical assist for hybrid vehicles
Submitted by Ed Reilly
Uses exhaust gas to turn a generator in a hybrid vehicle, reducing the engine load and the time the engine needs to activate
The turbocharger is connected to a generator or alternator to help recharge the electrical system. Exhaust gas pressure & electrical system are both monitored to optimize system control for best performance.
3rd place:
Dynamic cylinder deactivation with residual heat recovery
Submitted by Yuanping Zhao
Improves on traditional cylinder deactivation by balancing the thermal load of the engine and reducing overall operating temperature
Cylinder deactivation is a proven method of conserving fuel and reducing CO2 emissions under cruising conditions. It has been adopted by most OEM's and is used in the marketplace today. Dynamic cylinder deactivation improves on the traditional approach by balancing the thermal load in the engine. Using microprocessors, the cylinders are deactivated in an intermittent and balanced method, as opposed to only deactivating particular cylinders. The thermal load is also balanced by using alternate cylinders, which allows the engine to work at a lower overall temperature. This leads to better engine performance, improved fuel economy, and lower NOx emissions.
See also: Rev Up Fuel Efficiency (results not yet posted as of Oct 31, 2008).
Old 10-31-2008, 08:47 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Sounds like they took existing good ideas and tweaked them a bit. Not bad by far.
Old 05-15-2011, 03:14 PM   #3 (permalink)
Thumbs up Dynamic Cylinder Deactivation
Actually "Dynamic Cylinder Deactivation" was the First Prize winner.
This up-to-date technology has been made into aftermarket engine
retrofitting product now, yielding 10% to 18% fuel savings.
Old 05-15-2011, 03:24 PM   #4 (permalink)
Thumbs up Dynamic Cylinder Deactivation with Residual Heat Recovery
The First Prize winning article "Dynamic Cylinder Deactivation with Residual Heat Recovery" has been posted online ---- autoelectronics.com
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 03:29 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 31 01-18-2011 11:48 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 10:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 01:22 PM
