Old 09-30-2011, 02:20 PM   #1 (permalink)
Winter Blend?
Is there a formula for when gas companies switch from Summer Blend to Winter Blend gas? Is it by temp or by a certain date each year?
Recently (mid to late Sept) I've noticed a significant MPG drop. Temps have been cooler, winds have been pretty high, but it still seems like more than that.
I realize all of the fluids/greases are at a higher viscosity now (mid 50s) than in summer as well, but the car is in the garage so the differences are not huge at this point (60s now, 80s in summer).
Thanks.
Jay
Old 09-30-2011, 06:29 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...GOOGLE "Winter blend gasoline"
...here's EPA document: http://www.epa.gov/otaq/regs/fuels/rfg/f01033.pdf
...quote from the EPA website:
"Volatility/Reid Vapor Pressure (RVP)
Volatility is the property of a liquid fuel that defines its evaporation characteristics. RVP is an abbreviation for "Reid vapor pressure," a common measure of and generic term for gasoline volatility. EPA regulates the vapor pressure of gasoline sold at retail stations during the summer ozone season (June 1 to September 15) to reduce evaporative emissions from gasoline that contribute to ground-level ozone and diminish the effects of ozone-related health problems."
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 09-30-2011, 06:55 PM   #3 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Some gas stations here in Canada implement their Winter gas blends from November until early March I believe. I know my mileage takes a nose-dive when using those blends and when temperatures get really low (-20F).
35 MPG (winter blend) vs 40 MPG. (normal blend)
Here's the one from Petro-Canada : http://www.petro-canada.ca/en/wholesalefuel/318.aspx
Old 09-30-2011, 09:19 PM   #4 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
I'm definitely of the opinion that the gradually decreasing temperatures this time of year do a lot to mask the effects of fuel blend changes. For all I know, the winter blends may actually give better mpg than the summer blend, if used under matching weather conditions.
I googled "winter fuel blend" and "winter blend gasoline", and learned a few things.
Most interestingly, it seems that the summer fuel is the blend that is a "revision" of the winter blend, not the other way around. Summer fuel must have a lower Reid Vapor Pressure, or RVP, otherwise it will boil within whatever container it is stored, at summer temperatures. I think this is what is called "vapor lock", and it's no fun when that happens to your vehicle. BTDT, over 20 years ago back in the old days. Given their choice, fuel blenders would provide "winter blend" year 'round because its ingredients are less expensive.
I found a reference stating that the shift to winter fuel begins on Sept. 15. It appears that this is the start of a gradual shift towards higher RVP blends, however I didn't find that explicitly stated.
Then there's the shift to summer fuel...
"...will require tank terminals to accept only summer grade RFG beginning
April 15 of each year... However, tanks at terminals must contain only summer grade RFG by May 1."
Here are some links re. summer/winter fuel blends:
A Primer on Gasoline Blending « EPRINC (a detailed article)
What's the difference between summer blended gasoline and winter blended gasoline? - Yahoo! Answers
HowStuffWorks "Why is summer fuel more expensive than winter fuel?"
HowStuffWorks "Summer-grade versus Winter-grade Fuel"
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
The Following 2 Users Say Thank You to brucepick For This Useful Post:
Mifunego (09-30-2011), pazosgd (10-01-2011)
