Old 10-30-2009, 09:59 PM   #1 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 42.85 mpg (US)
Winter success!
Not quite winter just yet, but winter gas is here and the temps are down so it was time to fight back. In the summer I was averaging around 43mpg on my commute. When the winter gas hit and temps dropped I was struggling to get 40mpg. I recently added a HAI and rear wheel skirts and along with a vacuum leak/lean burn thing I've been playing with, I've seen some tremendous results. The last three days of commuting have averaged 44.4mpg! I'm pretty excited about getting the same mpg in the winter as in summer.
It seems this combination of mods has been paticularly effective on the slightly down hills where I must keep the throttle open and can't coast. I used to get high 50's to low 60's mpg in those areas and now am getting high 70's to low 80's in those areas. It also takes a bit more throttle angle to climb the up hills. Open road mpg is slightly better, but not as dramatic as the slight down hills. The up hill mpg is pretty much the same as before. Also coasting has benefited from the better aero.
So here are some pics of the different mods: Vacuum Leak, HAI and Skirts.
Old 10-31-2009, 02:20 PM   #2 (permalink)
40MPG+ is my first goal
Green Dart - '96 88
90 day: 33.87 mpg (US)
how did you make the vacuum leak work?
i want to try it
Old 10-31-2009, 09:11 PM   #3 (permalink)
Team ZX2
Originally Posted by IsaacCarlson View Post
i want to try it
go go go !
Old 11-01-2009, 01:53 AM   #4 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 47.91 mpg (US)
Josepha - '08 xD
90 day: 36.07 mpg (US)
Yes,, aerodynamics are even more important in cold weather -- the air is denser so lower drag helps more. My worst tank average all last winter was 41mpg, and this winter I have video mirrors and partial front skirts, too.
http://neilblanchard.vox.com/
Old 11-01-2009, 02:07 AM   #5 (permalink)
Zuk - '88 Samurai
90 day: 18.23 mpg (US)
Be careful with the vacuum leaks to get lean burning. There is an area from 50 degrees rich to peak egt that you can damage pistons and valves at higher power settings. If you are able to get leaner than that you will be good to go. Also if your calibrated leak is not in a central location you may be just getting one or two cylinders lean and not all of them.
Old 11-01-2009, 02:54 PM   #6 (permalink)
old sube fan
oldscoob - '87 wagon gl/dr
90 day: 26.36 mpg (US)
Could someone tell me why my car notices no changes for aero? I am simply 40s mpg in a 2750 pound sube wagon. It uses more to warm up in the winter, then wot is wot as normal. I even put the steel bar roof rack back on, and it even whistles...no difference...fold in mirrors? who cares!
at 1781cc, and a little carb (if 280cfm for the displacement is considered "little")...why isn't the aero drama applicable?
I resorted to getting intake, heat and cold mix just right, and tune up...40s mpg, and summer of course brings more on the highway..I have chuckle out loud at how far above 40s mpg it goes..no concern for aero whatsoever.
It is even a square looking car, all wheel drive, all those heavier bearings and axles, and driveshaft and rear end..and ten gears in the 4lo-hi tranny...
Why? anybody?
I have a conclusion....
Old 11-01-2009, 04:28 PM   #7 (permalink)
Polymath in training
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 xB
90 day: 48.45 mpg (US)
0-60 in 7 seconds - '02 SE-R Spec V
90 day: 39.71 mpg (US)
Small sample size. One tank is too low a number to be drawing conclusions from.
Darrell
6MT. 37.9 mpg avg over 11450 miles
5MT. 45.6 mpg avg over 10,950 miles
Old 11-01-2009, 04:33 PM   #8 (permalink)
SentraSE-R's Avatar
Bestclimb is right. I burned holes in six pistons on a one cylinder 90 cc. Suzuki trail bike. It happened like clockwork every 2,000 miles. Then I remembered I'd changed the fender from a low mount to a high mount when all the piston burning started. I changed back to the low mount fender, and no more holed pistons. That little disruption in cooling air flow caused dangerous high temperatures. I hate to think what a vacuum leak can do.
Darrell
Old 11-02-2009, 01:34 PM   #9 (permalink)
Team ZX2
Don't worry, I'm more crazy than smart, and I'm pretty crazy
I happend on the vacuum leak thing by accident. Typicaly when I have a vacuum leak with this car, and it's happend a few times in 256K miles, it will surge or ping a bit on accel. This time I forgot to hook up this line, which happens to be a calibrated leak from the factory (you can check out my other thread for details), and I had no drivability issues, just a check engine light telling me it was lean and I was suddenly getting much better mpg. With no driveability issues, and an abundantly cheap supply of these motors, I'm willing to let it go and see what happens. Of course I am not going WOT while doing this
All seems well so far, I'm half way thru the third tank will all three of these mods and the results are still the same. However, this is the first tank of commuting. I'm interested in seeing how much of a difference it makes when it gets really coooold.
Old 11-02-2009, 05:28 PM   #10 (permalink)
Stop Saying That!
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 40.5 mpg (US)
Her RAV4 - '08 Rav4 4x4
90 day: 24.92 mpg (US)
I still have my line disconnected and have yet to get a SES light (4 tanks so far, 1600 miles or so). I did put a restrictor in the line that reduced the size of the leak to approx. 3/16" dia. to prevent a light. Seems to be working. WOT when the engine is warmed up seems to be much peppier, probably the timing is advanced. Maybe someone over at ZX2uner would be willing to give it a try to see if there is any performance gain.
Craig Moore
Mancelona, MI
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 02:38 AM
Success with the Neon to Larger Car mavinwy Success Stories 1 01-14-2009 11:32 PM
Winter metroschultz The Lounge 4 12-12-2008 09:37 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 11:31 PM
[MetroMPG.com] List of reasons why your winter mileage is so bad MetroMPG General Efficiency Discussion 9 12-07-2007 01:19 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
