Old 04-27-2012, 03:43 PM   #1 (permalink)
kurzer's Avatar
Knut - '07 Toyota Prius
90 day: 50.9 mpg (US)
Santa - '00 Hyundai Santamo
90 day: 29.07 mpg (US)
wiper closer to the car
today i had an idea. the wiper arms of my car are not so close to the body, as i wanted them to be. so i spend some time, fiddeling with file and wrench. i tried to make the hole somewhat deeper and with an angel, to set the wiper arm closer to the car and more hiding behind the hood.
after the intial filing, i pushed the wiper omto its shaft and in the right position, and moved the arm to grind it in.
the drivers arm is now about 4mm, and the other is 5mm closer to the car. sounds not mutch, but looks good for me.
kurzer Gruß
Prius II
Hyundai Santamo
Old 04-27-2012, 03:49 PM   #2 (permalink)
I can take the wipers clean off and not be able to detect any differences. If you can detect a reduction in wind noise perhaps you are on to something.
NeilBlanchard (04-27-2012)
Old 04-27-2012, 04:01 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
It's because you are in that " damned pressure bubble " Frank !
Old 04-27-2012, 04:05 PM   #4 (permalink)
Yeah- my ol' skool 3-box cars and trucks. His Prius is sorta 1-box so...?
Old 04-27-2012, 04:42 PM   #5 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The Prius? I wasn't aware it had /any/ box...
"ŋʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 04-27-2012, 06:00 PM   #6 (permalink)
kurzer's Avatar
itīs the santamo, not the prius. notice the korrosion? this canīt be the prius!
in fakt the prius is better shaped, but i will give it the same trick, once i will oil the wiper shafts. it costs nothing but a little efford. and the car is better looking. i know, i know, looks are not important for a hypermiler...
kurzer Gruß
Prius II
Hyundai Santamo
Old 04-27-2012, 06:03 PM   #7 (permalink)
Looks are important to some hypermilers, actually. If we can make substantial mods that either improve, or at the very least, don't detract from, the overall appearance of the vehicle being modified, we're more likely to attract a larger overall fan base, meaning more collective knowledge, and information to apply to the hobby.
Old 04-27-2012, 10:18 PM   #8 (permalink)
Wiper blades will make almost no difference to the drag. Try putting a small leaf or blade of grass next to the blade, and then drive. Unless you get a crosswind, it will probably stay put.
Cd (04-28-2012), Christ (04-27-2012)
Old 04-28-2012, 02:42 AM   #9 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Yes, some (ahem) take pride in the quirkiness of their hypermiling vehicles.
I recon with this windshield mod you'll save at least 8mL of gas every year!!
The Following User Says Thank You to Sven7 For This Useful Post:
Christ (04-28-2012)
Old 04-28-2012, 04:52 AM   #10 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
As Frank said, they don't make a difference if they are hiding in the angle made by the bonnet and the windshield.
On cars where the bonnet and windshield form (nearly) one line like the prius and others, there's no or not as big a bubble for the wipers to hide in.
Hiding the wipers is good practice as it reduces pedestrian injuries in case of an accident.
