Old 05-14-2010, 12:52 PM   #11 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
The one I built, which has been in use for years, is based on a rubber diaphragm. I think that the friction in a syringe would cause wide swings between on and off. I used a small,strong tin can from yeast, and bound the rubber drum-head on with windings of rubber strip. The vacuum hose fits on a soldered-in tube. The microswitch is bare, mounted on a hinge, and gets pushed into the drumhead by an adjustment screw. You could probably use a jar, and glue the vacuum hose into the drumhead.
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Vacuum gauge DifferentPointofView Instrumentation 18 10-24-2008 03:31 PM
injector pump leaking on vw diesel diesel_john Off-Topic Tech 2 02-18-2008 03:33 PM
Brakes, EOC (engine off coasting) and reserve vacuum Lazarus Hypermiling / EcoDriver's Ed 5 01-24-2008 08:17 PM
Year end stats for Woo Lazarus The Lounge 0 12-28-2007 12:28 PM
