Wood gas?
Has anyone built a wood gas system? :turtle:
I've been toying with powering a small tractor with a FEMA-type wood gasifier (with a cyclone and a filter system for the tar) |
What did you want to power with it?
Something like a wood stove or boiler or something like a piston engine? |
a small piston engine.
That the same idea as the coal-gas engine conversions the brits did back in the war or whenever it was?
not only brits, a lot of countries had wood gas at the time of the war.
the engine would be a 10-something hp engine.
One thing I do remember is people saying that wood gas roughly cuts the engines power output in half.
exactly. That's why I need a 10-something hp engine.
The gearing will be super-low though, as the top speed only needs to be about 9Mph. It will pull a small trailer :) |
but I can't make my mind if should build a updraft or a downdraft (or a sidedraft) gasifier. The fuel is going to be very inconsistent in quality and size.
The gasifier system also needs to be small in size. |
And if the fuel is 'inconsistent in quality and size' you could add a chipper/shredder render it consistent. |
