12-14-2016, 11:54 AM
Volvo-driving MachYeen
Wood gas?
Has anyone built a wood gas system?
I've been toying with powering a small tractor with a FEMA-type wood gasifier (with a cyclone and a filter system for the tar)
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
12-14-2016, 12:14 PM
What did you want to power with it?
Something like a wood stove or boiler or something like a piston engine?
12-14-2016, 12:58 PM
a small piston engine.
12-14-2016, 01:10 PM
That the same idea as the coal-gas engine conversions the brits did back in the war or whenever it was?
12-14-2016, 01:13 PM
not only brits, a lot of countries had wood gas at the time of the war.
12-14-2016, 01:55 PM
the engine would be a 10-something hp engine.
12-14-2016, 02:05 PM
One thing I do remember is people saying that wood gas roughly cuts the engines power output in half.
12-14-2016, 02:16 PM
exactly. That's why I need a 10-something hp engine.
The gearing will be super-low though, as the top speed only needs to be about 9Mph. It will pull a small trailer
12-14-2016, 03:05 PM
#9 (permalink)
but I can't make my mind if should build a updraft or a downdraft (or a sidedraft) gasifier. The fuel is going to be very inconsistent in quality and size.
The gasifier system also needs to be small in size.
12-16-2016, 02:59 PM
#10 (permalink)
Well, there's a problem. https://www.google.com/search?q=wood+gas+ca Looking at the Images of presumably successful installations, compactness is not apparent. Most successful seems to be VW, with a 'power bulge' on the hood and the filters underneath the floor.
And if the fuel is 'inconsistent in quality and size' you could add a chipper/shredder render it consistent.
