Old 11-04-2013, 09:48 AM   #301 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by 320touring View Post
you starting a thread for the car?
I know, I know I should ...
I for one would be intrigued to see what the CNG setup looks like compared to LPG
  • CNG is stored as a gas despite the 200 bar / 2900 psi tank pressure - LPG is stored as a liquid.
  • 2-stage pressure reduction system, the 2nd stage using variable output pressure based on the engine's demand and is heated by the engine coolant.
  • large, voluminous cylindrical tanks for CNG rather than space-saving donut type tanks for LPG.
  • VW have increased the compression and fitted hardened valves + seats, so no messing about with valve lube etc. like with LPG
    (valve lubing is often needed on retrofitted CNG cars though)
  • Monovalent car, so the driver can't select which fuel to use (which you can in LPG or CNG-retrofitted cars) - it runs on CNG until the tanks are empty.
Old 11-04-2013, 01:01 PM   #302 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Consider thyself admonished!
[*]CNG is stored as a gas despite the 200 bar / 2900 psi tank pressure - LPG is stored as a liquid.
Hmm- thats some pressure-similar to a modern common rail diesel- guess it explains the tanks!
[*]2-stage pressure reduction system, the 2nd stage using variable output pressure based on the engine's demand and is heated by the engine coolant.
Similar to a vapourisor on an LPG setup? except with pressure control as well. sounds good- inso far as it is load reactive
[*]large, voluminous cylindrical tanks for CNG rather than space-saving donut type tanks for LPG.
How does that impact on the available space in the Up!? does it reside in the location usually reserved for the petrol tank?
[*]VW have increased the compression and fitted hardened valves + seats, so no messing about with valve lube etc. like with LPG
so similar to LPG in that its a drier fuel than petrol, and some cars can suffer valve seat recession due to using it? Jaguars need valve lube for LPG, but the BMWs I have are happy without it
Interesting re the compression! does CNG have a higher RON rating, but lower calorific value?
[*]Monovalent car, so the driver can't select which fuel to use (which you can in LPG or CNG-retrofitted cars) - it runs on CNG until the tanks are empty.
ah, so no handy "range extender" option then? I did like that about LPg
Cheers for the insight (ecomod punFTW!)
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 11-04-2013, 06:20 PM   #303 (permalink)
euromodder's Avatar
Yes.
The 2 gas tanks are underneath the car, one on either side of the rear axle.
The fuel tank is reduced to 10 liter / 2.6 US gal .
There's no well for a spare wheel - which I haven't been carrying for the last 3 years anyway. You do get a compressor and some fix-a-flat gooey ...
The trunk floor is mounted a few cm higher - and lacking the well.
The whole CNG system adds about 100kg - most of that is the weight of the tanks.
Yeah. CNG doesn't lube at all.
It's 130 RON.
Caloric value of the gas I use most often is low, below 10.
After the gas is gone, there's only the 10 L petrol tank.
I chickened out at 9.5L recently.
Effectively giving a 528km combined range.
10L should be OK for some 200km, but as the car briefly uses petrol after tanking CNG (100 yards or so) you never really know how many km it has done on petrol.
VW wants you to replace the petrol every 6 months to keep it from going stale.
So the first 2 years, that's what I'll do
Cordless Electric Lawn Mowers Do Work! rgathright Saving@Home 21 12-09-2011 10:08 AM
From 15 to 23.75mpg in a 5500lb work truck JacobAziza EcoModding Central 21 12-04-2009 01:38 AM
Will this work for my metro thefirebuilds General Efficiency Discussion 4 12-27-2008 11:45 AM
Scangauge doesn't work lovemysan Instrumentation 2 09-01-2008 10:49 PM
Request for 'work in progres' thread Daox Forum News & Feedback 4 12-23-2007 10:03 PM
