Old 10-30-2009, 12:02 AM   #41 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Originally Posted by basjoos View Post
I wonder what kind of mileage the Aerocivic would get with a diesel engine from the Polo
Do you have any info for the minimal BSFC of your current engine? IIRC, the 1.2L TDI was around 190g/kWh at best, so just compare that to whatever the D15Z1 is at. That said, your gearing probably isn't optimized considering how low the load must be w/ a Cd=.17 or whatever you're at, so that's where the most gains could be. Anyway, in terms of peak thermal efficiency, the lean burn engine in the Insight was the best I've seen from a production vehicle IIRC.
Old 12-31-2011, 04:05 PM   #42 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Does this guy ever plan on releasing a how to thread?
I wouldn't mind knowing how to get a lupo non tdi over to wisconsin.
Especially if he has a kit
Old 01-01-2012, 11:13 AM   #43 (permalink)
Insight 1G - '00 Insight
90 day: 79.26 mpg (US)
Once upon a time I had a website devoted to the project (redlightracing.org). My buddy was taking care of the server space and that fell through the cracks. I'll see if I can't get the problem resolved. It'd be a shame to lose all the content that was generated.
I'm afraid kits won't be forthcoming. The time and expense just don't make offering a kit feasible. I'd be happy to help people with their own projects. At a point in the near future I'll have a robust electronic adapter module put together which, quite frankly, was one of the most difficult parts of the build. The mechanical part was relatively straight forward. Wiring was tough but again, not bad compared to figuring out how to get the electronics to play nice with one another.
Old 01-01-2012, 12:35 PM   #44 (permalink)
rmay635703's Avatar
My recommendation if you ever get a website setup again, (this applies to anyone) is to be sure that right away once its up and running to submit it to google and to go to archive.org and try to view historical pages of your website, this normally puts it in queue to be archived, thus no matter what the website would not get lost and you can reference it once the site goes down)
The one thing is though you need to make sure the robots.txt is setup to allow everything to be indexed, I really wish some of the really old forums had been setup to allow archiving because there was a lot of neato technical discussion on several forums I used to frequent in the 1990s that are lost to the recycling bin of time.
What service did you go through to get the LUPO? I would very much like to get a LHD non-turbo lupo but have absolutely no idea what would be required to even attempt. (I would be more apt to putting it in an antique VW vehicle or the Miles I retitled, not necessarily an insight... though that would be sweet if I could find one reasonably.) I also wonder if there are any modern common diesel motors that are as efficient as the VW 1.2 that are either smaller or non-turbo, the vehicles I am considering for conversion are very very light and wouldn't need much to get going. The other issue would be gearing.
How much did it end up costing to get the vehicle and get it here, if you don't mind divulging?
I also wonder what forms I would need to fill out.
(sorry for being such a nuisance but these things are really interesting to me)
Old 01-01-2012, 03:27 PM   #45 (permalink)
I went through Classic Motorcars International to get my Lupo. Erik was a friend of a friend who took good care of me. He does a lot of car imports for people and is very familiar with the process. I will say bringing cars into the country is a difficult, time consuming, and costly proposition. It's much easier and cheaper to bring parts in as long as you know what parts you want.
The Smart diesel would be one way to go. You can source them from Canada which would be more convenient than going through the Europeans. It's a turbo charged 0.9L but based on my experience, you want the turbo charger for automotive applications. They make the engines much more responsive and efficient. With a turbo you don't need to carry as much displacement to get the performance you need to keep the vehicle from being a hazard to yourself and others.
The Lupo cost me about $8k when all was said and done. Erik can point you to all the forms you'll need to fill out if you'd like to import a vehicle. The primary agencies you'll have to deal with are: 1. EPA (always fun) 2. Federal Department of Transportation (even better) 3. US Customs. No. I didn't have a lawyer and I'm not a lawyer so I had to get good and reading/interpreting federal regulations.
Not a nuisance at all. Here's a build photo album to give you an idea of what the swap was about.
Best wishes,
Jake
The Following User Says Thank You to jpstaub For This Useful Post:
CigaR007 (01-01-2012)
Old 01-02-2012, 02:26 PM   #46 (permalink)
rmay635703's Avatar
Thank you, not sure if the full motor and drivetrain/front wheels would be cheaper than a full car or not. ( I would try to set the donar on top of the whole kit and kabootle if I could)
From what I hear smart diesels don't last...
Up here in the great white north turbos have less than stellar reps, I would take a good non turbo if I can find one, power won't be an issue. Cold weather and pollution controls don't mix with turbos, my father has had to clean the intake and turbo on his VW every couple of years, 5cyl Sprinters get the black crud of death after a few years of winter operation and even some gasser turbos aren't much fun here. Up here if you run a diesel in winter and don't do just long trips you don't want a turbo.
Best wishes,
Jake
Thank you for the info, $8k really isn't that bad considering how much VW itself wants to charge for motors and transmissions.
I think it would be worth it to save up a while to have a unique ride. I wonder if the 1.2 can be "un" turbo'd, I would like to detune and remove as much potential for reliability issues as possible. My little 900-1700lb donar vehicles should run well enough on a 1.2 FI diesel
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
FS: All USED Honda Insight Parts For Sale Fabio For Sale 15 12-20-2011 08:29 PM
Honda Insight Becomes Japan’s Best-Selling Car SVOboy EcoModder Blog Discussion 1 09-14-2009 06:36 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
New Honda Insight Already Beating Expectations SVOboy EcoModder Blog Discussion 2 02-25-2009 09:21 AM
