Old 08-13-2008, 05:28 PM   #1 (permalink)
would it be alright to add a KN filter
I have 08 highlander,when I got ready to change it,I found a pre filter with a air filter.Most people tell me that toyota have a good filter,but I want to save on MPG.The pre filter,is made from nylon bands,I couldn't see very much light thru it.What's your opion.THX Again
Old 08-13-2008, 06:38 PM   #2 (permalink)
K&N
My opinion is,don't.Science says you'll never see a benefit at the gas pump.I used to use a Filtron-sock(pre-cursor to K&N),air cleaner on my race bikes when I was younger and more ignorant.Now I'm older and a little less ignorant,and while K&N's hype does speak to my intuitive side,the science does not bare out their claims,and I will use nothing but a micronic paper filter element as is standard on your Highlander.K&N has found a great way to sell cheap oil for alot of money.
Old 08-13-2008, 09:33 PM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I would replace it with a quality air filter like Baldwin and leave it at that.
Old 08-14-2008, 07:02 AM   #4 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Autospeed.com did a nice set of articles on negative boost in the intake. If I remember right the air filter was responsible for 7% of the restriction of the whole intake. Even if a K&N would halve this restriction, the impact on fuel economy of an hypermiled vehicle would be lost in the tank to tank mpg variability noise.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 08-14-2008, 09:30 AM   #5 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 17.6 mpg (US)
Heep - '011 Grand cherokee Larado x 4x4
90 day: 19.92 mpg (US)
Old toy - '81 Cm400e
Da bike - '06 Shadow Vlx deluxe
90 day: 50.18 mpg (US)
fe wise no (toyota 3 stage filter work great as filters. go amsoil filter if u want a better on than k'n)
hp wise fill up with 93 for 3 tanks, and u will feel a difference, that vvt-i and 3.5 (2gr loves high test, but for some reason for toyota to get the full effect of anything about 3 tanks worth must be run through it.
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Air filter saunders1313 Hypermiling / EcoDriver's Ed 33 07-03-2010 11:35 AM
Larger oil filter for better FE? Gregte DIY / How-to 44 05-22-2010 11:12 PM
Best Air Filter lucidexp EcoModding Central 33 01-09-2010 10:55 AM
Debate continues: K&N filter vs. MPG DifferentPointofView EcoModding Central 39 12-16-2009 06:46 PM
Broken Air Filter Discovered RH77 Off-Topic Tech 2 07-03-2008 10:14 PM
