Old 09-08-2009, 02:20 PM   #1 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
would creating a small vacuum leak after your MAF sensor
lead to a small increase in mileage by leaning the mix a little or would the o2 sensor/vac sensor pick up on that?
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 09-08-2009, 02:41 PM   #2 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
The O2 sensor will pick it up and adjust the fuel trim accordingly.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 09-08-2009, 03:26 PM   #3 (permalink)
DANG!!!! nt
1991 F-250:
Old 09-08-2009, 06:01 PM   #4 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Unless the leak is so big the ECM can not compensate
Old 09-08-2009, 09:51 PM   #5 (permalink)
Moderator
In which case it'll just ignore the MAF, throw a code, and trust the 02.
Old 09-08-2009, 09:53 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
it will code, and stumble. O2 cannot react quickly enough to make it smooth.
Old 09-09-2009, 07:26 AM   #7 (permalink)
Moderator
I'll unplug my MAF on my Elantra to test. I'm pretty sure there is a default map the ECU uses as a baseline if it can't get a response from the MAF.
Old 09-09-2009, 07:41 AM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
no maf signal at all is different than air bypassing the maf. You will probably get a "no maf" code instead of a "too lean" code.
I just replaced a leaky intake hose that was downstream of the maf. Had some major flat spots on acceleration (and a too lean code).
Old 09-09-2009, 12:32 PM   #9 (permalink)
Team ZX2
Well, I recently had a vacuum hose disconected after the MAF, drove four days that way and the mpg inceased by about 1. There are other factors though, all new accessory pulleys and time belt pulleys were the reason the vacuum line became unpluged. Pluging it back in this week has returned me back to the normal mpg. I can't totally explain this, just an observation until I get more time to test it out.
Old 09-10-2009, 10:43 AM   #10 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 40.5 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 24.98 mpg (US)
This would not really be a vacuum leak, it is an intake air leak. There is no vacuum in the air intake runner, only vacuum is after the throttle plate. However, an air intake leak would allow unmetered air to bypass the MAF. This would result in lean condition, but a small leak may not throw a code, as long as the adjustments made by the ECM keeps the O2 sensor information in the proper range. The ECM does not only adjust fuel trim; but also the ignition timing and on our engines, the variable cam timing (exhaust cam). The O2 sensors operate in a range that is considered normal. Maybe you were running on the lean end of normal?
I believe you are running the 5.6K resistor in your IAT? The air intake leak would have the same affect, it would be fooling the ECM into thinking there is less mass of air flowing through the intake (since some would be going around the MAF not through it), so it would adjust the fuel trim, timing and cam. Maybe the leak was acting similar to your resistor?
PS: Let me know which line that was! I want to test it out.
moorecomp
Mancelona, MI
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 06:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
lean burn: now i have a 1k pot on my MAF sensor modmonster EcoModding Central 17 01-21-2009 01:07 PM
MAF sensor life Daox Off-Topic Tech 9 03-25-2008 02:29 PM
