Old 02-03-2012, 07:21 PM   #1 (permalink)
Debonair's Avatar
Camaro - '00 Camaro SS
90 day: 16.18 mpg (US)
S10 - '95 S10 LS
90 day: 20.69 mpg (US)
Would I see positive numbers with a belly pan on a stock height truck?
From what I see people have lowered and created belly pans.
I don't plan on lowering my truck, but am interested in doing a belly pan for numerous reasons.
Granted it wouldn't be equal gains, but would i see some sort of gains in fuel economy?
[url=http://ecomodder.com/forum/em-fuel-log.php?vehicleid=5445]
Old 02-03-2012, 07:24 PM   #2 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
Yes. Phil (aerohead) has posted aerodynamic studies where OEM's have increased aero efficiency anywhere from 5%-15%, usually resulting in just a couple MPG.
aero mods-data-% change or Cd change ( installment #6-underside/bellypans )
You would have better luck with an aero topper (see the home page) that has been unofficially shown to improve gas mileage by 20%.
Commercially produced aerodynamic pickup bed cap
Also look into an air dam made of lawn edging, or maybe an S10 Xtreme bumper/lip. This will push air to the sides, away from the turbulent under body.
But of course you already know that the most useful way to approach this is many small measures adding up, instead of putting all your hopes into one mod.
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
The Following User Says Thank You to Sven7 For This Useful Post:
Debonair (02-03-2012)
Old 02-03-2012, 09:09 PM   #3 (permalink)
Debonair's Avatar
S10 - '95 S10 LS
That's good to know, other than fuel economy it would be A LOT easier to clean the underside (if i go aluminum) and wouldn't have to worry about rust as much.
I planned on getting a retractable tonneau cover, for me it seems more practical than the topper.
All in due time though first is my ac compressor, then exhaust, then electric fan/new intake.
This will leave me enough time to plan how i'm going to go about this
Old 02-03-2012, 09:42 PM   #4 (permalink)
Schwinning!
Sven7's Avatar
Team Ford
Honestly, read BamZipPow's thread. I know Phil has a very nicely done Toyota as well, but don't know if he has a thread on it. After an election go to the campaign headquarters and ask if you can have some extra signs. The bigger, the better. They're made of coroplast and that will be extremely easy to make aero mods with. I installed a front belly pan on my Probe in an afternoon with nothing but coroplast, zip ties and a box cutter.
Debonair (03-03-2012)
Old 02-04-2012, 12:26 AM   #5 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Aluminum wont rust but it will cause the steel its touching to rust like crazy, I have to break down my trailer and repair steel that is starting to rust heavily because its been in contact with aluminum plate for 3 years.
For a truck under body I plan to go with galvanized sheet steel or something nonmetalic like plastic or fiber glass.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
Old 03-03-2012, 08:58 AM   #6 (permalink)
Debonair's Avatar
S10 - '95 S10 LS
Good thing its election year I could make it with that, then either leave it, or use it as a template if it go for some sort of metal.
how durable would the fiberglass be? or is it gonna be (as strong as you make it sort of thing) plus how would it hold up with the exhaust pipes being over it?
and whether i go with galvanized steel or aluminum, should i just put some sort of bushing all around? kind of like weatherstripping or something
Old 03-03-2012, 10:42 AM   #7 (permalink)
skyking's Avatar
Woody - '96 Ram 2500 SLT
90 day: 20.74 mpg (US)
Avion and Woody - '96 Ram 2500/5th wheel combo
90 day: 15.87 mpg (US)
The coroplast is remarkably durable in this application. If you worried about rocks and road debris coming up, remember it will simply give and pop back with most hits.
My truck is a rust bucket underneath. I can't wait to get my bellypan on.
1996 Dodge 2500 Cummins Turbodiesel
Custom cab, auto, 3.55 gears
Old 03-03-2012, 11:03 AM   #8 (permalink)
EcoRod - '97 Sentra GXE
90 day: 37.72 mpg (US)
Fiberglass can also be rigidized if you care to take the time and work. Get aluminum household screen and place that in between the layers of fiberglass. This creates a heck of a lot of weight though I would personally recommend, as others already have, to use coroplast. I took a bird to the coroplast on my bumper at 55 mph and aside from bird stuff, can't hardly tell where it hit.
Old 03-03-2012, 11:49 AM   #9 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
galinized steel?????????
!. you need to look at underbelly pans that have been done on the site. use the search function.
2. there is absolutely no rational to using something as heave as steel.
3. this idea has neen beaten to death like a dead horse.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 03-04-2012, 02:11 PM   #10 (permalink)
V8 guy
Pickups
When your empty weight is 5,800lb not too worried about weight.
But I will likely use Coroplast - Manufacturer of Corrugated Plastic Sheets for most of it, I was thinking the 26ga sheet metal would be good for places close to the exhaust.
