Old 10-15-2008, 07:36 PM   #1 (permalink)
Old Retired R&D Dude
Little Red - '012 Prius c 2 Two
90 day: 26.38 mpg (US)
Transporter - '09 Escape XLS
Would you trade your AC for some extra MPG??
I've been thinking about a plug-in mild-hybrid conversion for my CRV..
Then, I started thinking about that fuel wasting AC compressor..
What if it went bad and I just got rid of it? (And all the other AC parts).
What if I used the compressor mounting hardware to install a small PM motor?
Two or three Green HP to assist my CRV up hills etc?
If you could get a 15 to 30% percent increase in your MPG for 30 miles, by dumping your AC?? Would you?
Cheers,
Rich
Old 10-15-2008, 09:33 PM   #2 (permalink)
Civic - '98 Civic DX
90 day: 41.44 mpg (US)
nope..gets to hot here
Old 10-15-2008, 09:36 PM   #3 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
for a 30% increase, sure. I don't use it much anyways, just use the fan.
Most of my trips are made in rush hour traffic to and from school.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 10-15-2008, 09:38 PM   #4 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '010 Agility 125
If you're doing a mild hybrid conversion, you can always use an efficient higher voltage PM motor off the pack to drive the AC compressor. That way you'd be able to use a PWM controller to get exactly the amount of cooling you need regardless of RPM or load.
Old 10-15-2008, 10:04 PM   #5 (permalink)
Just beware that you'll have to recover the refrigerant before you cut any pipes. You'll need an EPA certification to do that. Unless, of course, the cause of failure was a broken pipe, in which case there will be no refrigerant left to recover.
The A/C compressor doesn't use that much power anyways. One datasheet (Danfoss BD250GH) referenced 230W at maximum capacity.
You can use a DC/DC converter to power the existing compressor from the high voltage batteries. If the high voltage is in the range of 150-350v, a PC power supply with active PFC can be modified into a DC/DC converter. The inrush surge might be a problem, but some multi-farad capacitors of the kind used in car A/V systems should fix that. If you need to replace the compressor anyways (which would require an EPA certification), you can check local HVAC supply shops for line voltage compressors (which can run from high voltage DC with a relatively simple MOSFET inverter), but some HVAC supply shops only sell to businesses.
There's also the option of silicon heat pumps, but they operate from low voltage DC, so back to that problem again. System design is also a little tricky.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 10-15-2008, 10:07 PM   #6 (permalink)
That's one complex way of turning grid juice into MPG..
Since I live in the NE, where my car AC gets very little use, it wouldn't be cost effective for me..
I'm thinking more along the lines of an old gas hog that maybe has a broken AC and they want $800 to repair it..
Plus, I'm sure there are a lot of hypermilers around that hardly ever use their AC..
When I was a kid growing up in south Texas, cars with AC were very rare.
But, somehow we lived with out ice cold air blasting on us..
Cheers,
Rich
Old 10-15-2008, 10:31 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Xringer -
I would, but my wife and/or other passengers would probably not appreciate it. I do know that for my car (and probably many others), you can replace the AC with a pulley that matches the dimensions/location of the AC compressor pulley. Here is one I could put on my car tomorrow :
eBay Motors: 95 96 97 98 Saturn S Series A/C Bypass Pulley 1.9 (item 280268263281 end time Oct-17-08 12:26:34 PDT)
Irony: My AC is broken right now anyway, .
CarloSW2
American Solar Energy Society
Old 10-15-2008, 10:31 PM   #8 (permalink)
I don't ever recall seeing a failed AC in a car that still had much refrigerant left in it..
Anyways, my post isn't asking how to better run or repair a car AC..
It's about the desirability of dumping your AC for better MPG..
Pretend it was a regular dealer option at a used car lot.
They both cost about the same..
Pick one:
A. 10,000 BTU AC system installed w/25 MPG unlimited miles.
(Until you turn on the AC, then it's 23.5 MPG).
B. Plug-In Mild-Hybrid system installed w/30 to 38 MPG for trips less than 20 miles.
(After 20 miles, it's back to 25 MPG).
Cheers,
Rich
Old 10-15-2008, 10:32 PM   #9 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
That model is only rated for a max charge of 300g.... I drive a midsize classed car (2000 Jetta), which is spec'd for a charge of 700g + 50g
Danfoss doesn't make a 750g model, but it does make a 800g max model... Which, under max load, draws 660W @24VDC
Now, 27.5 amps might not be too much compared to the KW the engine is putting out in total.... But, even daytime running lights (<55W per light) have an impact on FE. That and, I for one, see a drop in instant FE when I turn the a/c on....
Here's the data sheet on the bd350/350gh dual compressor
http://rc.danfoss.com/TechnicalInfo/..._ed100p202.pdf
That said, it would be cool to switch over to an electric compressor - there's some cool tricks you can do when you have finer control. I'd probably add a bigger accumulator, pwm the motor (as you mentioned) and move some componentry out of the engine bay Not to mention the option for a pre cooling cycle before getting into a car that has been well baked in Florida sun
EDIT
And to answer the thread....
Probably not given the current region I'm living in.... I wouldn't do this without installing an alternative cooling solution first.
Challenge me, or correct me, but don't ask me to die quietly.
Old 10-15-2008, 10:54 PM   #10 (permalink)
Originally Posted by cfg83 View Post
Xringer -
Attachment 1934
CarloSW2
I think mine is still running. They say it's good to turn it one for a few miles at least once a month.
I did use it a couple of times this summer when my wife was with me.
But most of the time when it's hot out, she prefers we take her car.
You better order that pulley while they last!
Cheers,
Rich
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
AC cooling off the engine?? Xringer Aerodynamics 16 08-21-2008 06:12 PM
AC on the entire time and I got my best MPG average ever?? regor Hypermiling / EcoDriver's Ed 12 06-24-2008 12:55 AM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
