Old 07-21-2015, 08:43 PM   #1 (permalink)
WPC Metal Treatment/Reduced Friction
When it comes to improving fuel economy, my overall goal has been to increase the efficiency of an engine. Recently, I came across a process known as WPC engine treatment which in summary, is micro-shot peening. Much like conventional shot peening, it makes the metal part stronger, while adding micro-dimples that act as oil reserves to the piece. This inherently makes the part slicker, whereby reducing friction.
My question to everyone is this; would increased friction add to fuel economy?
WPC - Metal Surface Treatment
http://ep.yimg.com/ty/cdn/twincamtec...011pricing.jpg
Old 07-21-2015, 09:38 PM   #2 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
friction on the cylinder walls maybe. anywhere else i can't imagine. crank, cam ride on bearings. parasitic loss from oil slosh can't be fixed either.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 07-22-2015, 05:00 AM   #3 (permalink)
So what you're saying is that for the biggest bang for my buck would be to have the cylinder walls treated. That's interesting because the engine building instructor at the local tech college once told me that fuel economy can be improved by the cylinders.
What would you say about having the treatment applied to the pistons, wrist pins, and piston skirts as well?
Old 07-22-2015, 05:03 PM   #4 (permalink)
Not banned yet
deejaaa's Avatar
those areas are not touching anything except wrist pins, in a VERY SMALL area... the only friction would be parasitic, such as splash.
i was hoping someone else would join in. your title sounded like unicorn material and i had to read it first to understand what you meant.
Old 07-22-2015, 08:05 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
My little Fiat engine has 'plasma coated' cylinder walls using 'formula one' technology. With the aim of reducing internal friction, quite a few OEM's are doing it
Old 07-23-2015, 03:20 PM   #6 (permalink)
That's interesting to hear because I investigated that option a few years ago. The problem was that each search on plasma coating seemed to lead me back to ceramic coating. Would you be willing to elaborate what exactly it was that you had done or even the process if possible? I've trying to determine if there's a distinction between the two.
Old 07-23-2015, 04:40 PM   #7 (permalink)
darcane's Avatar
Originally Posted by Davo53209@yahoo.com View Post
My question to everyone is this; would [reduced] friction add to fuel economy?
Simple answer: yes.
This is a focus on modern engine design in order to improve efficiency. Mazda's claim for the Skyactiv-D engine is that they reduced friction by 30%
Mazda Engines - Skyactiv-G Gasoline Engines | Mazda Canada
The SKYACTIV-G engine reduces friction inside the engine by 30%, improves oil pump efficiency by 74%, improves water pump efficiency by 31% and reduces friction in pistons, rods and crank shaft by 25%.
The Skyactiv 2.0L uses 15% less fuel than the old 2.0L Mazda engine. Partially due to friction, but it is also direct injected, higher compression, and has improved VVT. So, who knows how much is due to friction. Also, I'm sure significant design changes were made to reduce friction rather than just a surface finish.
So, can it help? Yes. Is this particular process worth doing for improving fuel economy and an existing engine? Very unlikely, unless it is cheap and you are rebuilding the engine anyways. And the prices you posted don't look cheap to me...
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
mcrews (07-23-2015)
Old 07-23-2015, 07:38 PM   #8 (permalink)
Originally Posted by darcane View Post
Simple answer: yes.
The intent is at some point to rebuild; but for now, I'm exploring potential options.
Old 07-23-2015, 10:33 PM   #9 (permalink)
...beats walking...
GM is claiming "diamond'ized" cylinder wall coating increases FE in current engines, but you couldn't tell it by our Cruze numbers.
The Following User Says Thank You to gone-ot For This Useful Post:
Xist (07-23-2015)
