Old 09-17-2009, 05:51 PM   #1 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
Wrecked my mileage!!!!!
two days ago we picked up my aunts trailer to pick up hay for our rabbits. It is maybe three feet wide and six feet long with two foot sides(all rotten plywood). I figured it would cut mileage to about 30.......NOT!!!!! more like 15-20 TOPS!!!!!!!!!!!!!! It took a QUARTER TANK to go to Chippewa Falls and back, about 60 miles round trip!!!! I didn't realize how much a small sail can affect mileage If i pull that thing again it won't have a front or sides.... The reason I didn't think it would change that much is because i can pull a friends STEEL 5x8ft road warrior and get 25-30. But it sits a lot closer to the back of the car(shorter toungue) so maybe it acts kind of like a boat tail???
If I build my own trailer it will be Heavilly aeromodded
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 09-17-2009, 08:06 PM   #2 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
The aero drag wasn't the only thing giving you bad mileage. The extra rolling resistance from the tires of the trailer (did you check the tire pressure?), and the extra weight are probably the bigger factor. Even though it's plywood, the frame is still heavy metal (I hope).
And, I'm guessing that the route you took wasn't a typical route, so you weren't able to plan it as well as you could if you drove it every day.
But aeromodding a trailer would look pretty awesome
Old 09-17-2009, 09:03 PM   #3 (permalink)
Yeah, i filled up the tires.
1991 F-250:
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
What is your city vs. hwy mileage ? Cd General Efficiency Discussion 34 02-16-2009 01:43 PM
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 5 08-11-2008 02:35 AM
