Old 05-20-2010, 10:51 AM   #1 (permalink)
Project EconoPolo - '04 Polo Twist TDi
90 day: 52.46 mpg (US)
Writeup/Pics of my front grille block on my Saab
I just completed my grill blocks on my new saab. Here's how I did it.
After removing the 3 grilles from the car:
I used polystyrene filled cardboard (used for signs etc) to make backing plates. I drew around the shape with a pen:
Then cut out the individual plates I needed:
Then I spraypainted the 3 plates in matt black to keep them hidden:
After a test-fitting:
I trimmed off any extra around the sides, using my dear wife's leatherman knife:
I then used a hot glue-gun to secure the backing plates to the grills:
After about 20 seconds held in place:
They were secure:
I refitted all 3 grilles to the car:
and you would never even know they were there:
Old 05-20-2010, 11:03 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Looks very nice.
I'd check back after a few weeks and again after a few months. Hot glue isn't the greatest stuff to hold things together.
Old 05-20-2010, 11:21 AM   #3 (permalink)
Good tip, thanks. I was originally going to try and use screws but couldn't get ones small enough at a fair price. Any alternatives to recommend?
Old 05-20-2010, 12:50 PM   #4 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Black cable ties?
Old 05-20-2010, 01:37 PM   #5 (permalink)
EcoPikey Modder
big_dave's Avatar
Kunnt 1 - '04 ForTwo Custom
Burner - '09 Soul Burner
Send a message via MSN to big_dave
Looks a lot tidier than the polo's mods
Old 05-20-2010, 02:25 PM   #6 (permalink)
You're a cheeky beggar Dave its a good job I like you.
Black cable ties aren't as stealthy as I'd like but they'd sure do the job.
Old 05-20-2010, 04:17 PM   #7 (permalink)
Wolfsburg - '03 Jetta 1.8t
90 day: 28.69 mpg (US)
I was wondering, is there a big difference in air flow between blocking the air before the grill, and after the grill, like you did ?
Old 05-20-2010, 04:40 PM   #8 (permalink)
Marginal benefit from blocking externally. Either way the air is forced to flow elsewhererather than into the engine bay, but this method keeps the standard look of the vehicle. In this method, air pressure will build up in the grilles slats before forcing it to "overflow" to the bonnet etc. Kind of like a bucket which must fill with water before it can overflow. I expect the difference would be slight.
It's been darn cold here... (cai delete + grille block) wdb EcoModding Central 17 02-25-2010 11:18 AM
Chevy AVEO: Adding grille blocks and air deflectors Thymeclock Aerodynamics 11 01-02-2010 04:39 PM
Civic grill block, front undertray, tire deflectors daqcivic Aerodynamics 24 05-13-2009 03:52 AM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
