You can check the ID plate on the lift, call Yale, and they can tell you anything you want to know about that motor.
They can also give you information on any other part of the lift.
That would be your best bet for accurate information, but they probably won't tell you what aftermarket uses it has. Once they give you the part number and such, maybe even the serial number of the motor, you can probably just google it and find out what you need to know.
