Old 12-16-2008, 04:49 PM   #21 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
Originally Posted by i_am_socket View Post
So I'm reading the other help threads and come across dcb's comment in the Guino KIT thread:
What do I do when both wires have 12 volts (power on, engine off)?
Uh, oh. If that connector is unplugged from the injector, and has 12 volts on both sides, there may be an issue. The computer/module (don't know Toyotas) grounds that ground wire for the length of time in milliseconds that it wants. It's possible there is a 12v feed on the ground side to prevent any fuel from being sprayed when not wanted, however...
I'm wondering now if your voltmeter can't catch the injector ground pulses fast enough to tell the difference. It still could be that you're on the wrong side of the injector...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Last edited by Intrigued; 12-16-2008 at 04:51 PM.. Reason: Waking up old brain cells...
Old 12-16-2008, 04:50 PM   #22 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
ECU pinout
Engine Control Schematics
Tapping the positive side from the ECU (yellow wire) actually showed the pulsing on my multimeter with the engine running. Since redoing to the negative line (black wire at the injector), there's a constant 12v either engine on or just power on.
Old 12-16-2008, 04:55 PM   #23 (permalink)
Intrigued's Avatar
Not
You're black is you're ignition hot. Your yellow is the pulse ground by your ECU... if I'm reading that correctly...
Old 12-16-2008, 05:04 PM   #24 (permalink)
Intrigued's Avatar
Yep, after looking at it further, you have a common hot, the black (and maybe with a white stripe) wire, coming directly from the ignition switch, and the four differently colored wires back to the ecu from the injectors are for grounding them separately... sequential fuel injection.
And I just love it that they would make a black wire the hot one.
Old 12-16-2008, 05:07 PM   #25 (permalink)
Intrigued's Avatar
And THAT, friends and neighbors, is one of the reasons that I never could make any real money diagnosing electrical problems...
Old 12-16-2008, 05:07 PM   #26 (permalink)
Ex-lurker
So I went through the trouble of wiring up to the wire inside the engine bay and running back through the firewall because I forgot to look at the little arrows, and actually had it right the first time....
Old 12-16-2008, 05:17 PM   #27 (permalink)
Intrigued's Avatar
Your mpguino ought to work now... and you can guess as to why mechanics wear caps a lot...
...to hide their flat foreheads they got from pounding them against the wall!!!
Old 12-17-2008, 11:57 PM   #28 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
And to hide their bald heads from pulling their hair out.
Winter daily driver, parked most days right now
Summer daily driver
Old 12-18-2008, 01:07 AM   #29 (permalink)
Intrigued's Avatar
AMEN PREACH It, Brother!!!
Old 12-18-2008, 11:24 AM   #30 (permalink)
Ex-lurker
I'll try swapping the wires tonight. I'll definitely let you know if it works.
Sounds a lot like working with computers. Dang machines do what they want instead of what they're told, and then there's dealing with the people that use them!
Looking for an "Aero Mod Materials" thread gascort Aerodynamics 7 05-06-2009 04:42 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
Change a thread title? wagonman76 Forum News & Feedback 3 06-27-2008 07:40 PM
the "Daily Drive" thread - March 2008 MetroMPG Hypermiling / EcoDriver's Ed 27 04-01-2008 10:46 AM
