You know you drive a junker/jalopy when...
http://ecomodder.com/forum/attachmen...1&d=1478791083
Click & Clack -- The Tappet Brothers -- had a good line on this topic: Quote:
Here's mine: With my winter beater 2000 Metro having some intermittent stalling-at-idle problems recently, I bypassed the clutch safety switch so that I had the option of moving the car a short distance using the starter motor in the event it stalled in traffic. That's confirmation (one of many) that I drive a junker! |
You know you drive a junker when... you're male. Females always have the new stuff.
When it breaks and you can actually fix it your self and it doesn't cost hundreds of dollars.
My driver's door responds best to gentle persuasion. Open the wind wing and flip the inside handle. Pull gently on the outside handle and trigger the latch if needed.
It broke down in traffic (first time in 15-20yrs) two weeks ago, but I fixed it with my bare hands, by draining the diesel fuel filter (since replaced) for a while. |
I know I drive a junker/jalopy when:
I look out the window at it. the carpet is always wet. I emptied the 4th can of expanding foam into the rust holes. the CV joints keep getting louder. |
YKYDJJW when you instruct your friend how to get the Volvo in reverse without the gearbox crunching
YKYDJJW when you have to gently knock on the headlight relay sometimes when headlights suddenly turn off YKYDJJW when you must often fill coolant because the hose leaks when cold YKYDJJW the engine leaks oil and you just shrug because the engine will be swapped this year and well, the underbody won't at least rust YKYDJJW you cross your fingers at the inspection |
YKYDJJW when you have to park your car on level ground because the engine no longer has good enough compression to hold its spot on an incline. (And the parking brake is busted.)
YKYDJJW your wipers only work when it’s dry, but if you hit the hood above the motor it starts working again. Also, it takes an extra batter and a boost from a running car to maybe get it to start.
And my vehicles all have active on-line owner sites, so they aren't jalopies, they're classics :-) |
