12-25-2016, 08:56 AM
#2091 (permalink)
Originally Posted by vandykkd
Youve done the Tiger Woods fist pump at the gas pump after filling up
I actually LOL'd at that one. Great visual! Thanks for the chuckle.
12-25-2016, 03:52 PM
#2092 (permalink)
Fingie — I had a Squareback with 185-60s on the back. At 45mph in 3rd, it hummed just like J. R. Cash doing the intro to I Walk The Line.
12-26-2016, 09:56 AM
#2093 (permalink)
Rat Racer
You believe theres only three necessary instuments on the dash. The fuel gage, the odometer and the vacuum gage. The rest are optional.
Fuel gauge? Fuel gauge? No, no, no. It's thermostat, trip mpg and odometer.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
12-30-2016, 09:41 PM
#2094 (permalink)
ScanGauge <3
YMBAEMI... you're out running errands with folks, and you get antsy at a stop, just knowing that the engine is losing heat while they dawdle.
Best tank (so far): 32 MPG
12-30-2016, 10:03 PM
#2095 (permalink)
when you keep putting the truck in 6th gear, despite the fact that you are breaking in a new engine and are not supposed to lug it. "but, but, the MPG gauge is crying"!
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
12-30-2016, 10:10 PM
#2096 (permalink)
YES YES YES!
When you are giddy at the arrival of the engine heater cord for your truck. Dodge, in infinite wisdom, installed a nice block heater in all the diesels of my model, and then made the cord a $$$$ option. Wow.
2003 TDI Beetle
2002 TDI Beetle
12-30-2016, 10:45 PM
#2097 (permalink)
ScanGauge <3
Originally Posted by skyking
YES YES YES!
Straight out of the software playbook -- put everything in the build, and charge the customer to enable options a la carte.
12-30-2016, 11:10 PM
#2098 (permalink)
Wannabe hyper..., miler !
It's not: " you know you're an ecomodder if" anymore but...,
YOU KNOW YOU MAY BE AN ECOMODDER IF,
"BTW"...
12-30-2016, 11:12 PM
#2099 (permalink)
I picked up a $10 outside lighting timer off the clearance rack at home depot. It is good for 1875 watts resistive, and is also designed to be out in the weather. One of my peeves about plugging in is how wasteful it is to leave a rig plugged in all night if you don't need it. Just figure out when to start the heat with a little trial and error.
2003 TDI Beetle
2002 TDI Beetle
12-31-2016, 12:38 PM
#2100 (permalink)
Volvo-driving MachYeen
you accelerate and drive aggressively, but still manage to get under the official MPG
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
