When there is a turn off ramp from a ground level street up hill to a stopsign at the end of an overpass ( going over the street previously on).... a veh. is coming up quickly from behind.... you signal, and pull over toward right curb.... there are no line markings anywhere.... you pull over early; hoping to give enough confidence to that following driver to blow by you... and even though you felt like you had to add a little brake pedal as an exclamation mark to MOTIVATE that guy..........
you still have enough momentum left to coast up to the stop sign, even though this is only the 2nd time tried here, and your practice is few, and far between, because you only drive through here about 3 times a month!!
Giddy SMILES!!!!
