Old 03-16-2010, 07:46 PM   #1 (permalink)
Iwishthiswasamanual - '98 Escort ZX2
90 day: 32.95 mpg (US)
Zx2 Fan- Always running
1998 Ford Escort ZX2
I just realized it while working on my car today that my fan runs 24/7. I thought it was only when the defrost was on, but not it seems that it's always running. Start it up, and its on.
Why is this happening? Normal?
Old 03-17-2010, 12:11 AM   #2 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 40.5 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 24.98 mpg (US)
The only 2 positions where the fan doesn't come on are the dash vent and the floor/dash vent settings. A/c, floor/defrost and defrost all cause the rad fan to run. It could be a stuck relay, try pulling the 15 amp a/c fuse in the under dash fuse panel and see what happens. If that doesn't do it, try pulling the relay and test it with an ohm meter to see if the contacts are welded.
moorecomp
Mancelona, MI
Old 03-17-2010, 01:54 AM   #3 (permalink)
Ac is removed. But I tried removing the fuse...no dice. Fan still runs on high.
Which relay should I be testing? Are you talking about part of the ccrm? Shouldn't I be able to visually see a bad solder?
Old 03-17-2010, 09:44 AM   #4 (permalink)
"Inconceivable"
moorecomp's Avatar
Team ZX2
Yes, it is part of the ccrm. Check the pins using the attached as a guide.
moorecomp
Mancelona, MI
Old 03-17-2010, 12:51 PM   #5 (permalink)
Relay was burnt out. Hopefully replacing it fixes it.
Old 03-17-2010, 11:00 PM   #6 (permalink)
Tried to replace the relay. Pulling it out messed up the traces because of the way they glued it on. Fan just doesnt run now. Replacement relay apparently didnt do anything.
Found a replacement at a junkyard though, picking it up tomorrow along with a few other things like the splash guard a mechanic lost.
Old 03-17-2010, 11:42 PM   #7 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
Be sure the part number on the replacement CCRM is the same as the original, otherwise it will not work properly. I know there are at least 2 (maybe more) different CCRM part numbers for the ZX-2.
Old 03-18-2010, 12:52 PM   #8 (permalink)
Just tried to different ccrms. One from an early 99 zx2 and one from a 98 escort. Car runs with it, so I'm sure its compatible (4 wire maf)
I'm going to double check this last one with a voltmeter.
The fan does not run now. Ever.
Old 03-18-2010, 03:02 PM   #9 (permalink)
Fan runs on high with thermostat temp sensor disconnected. Never comes on with ac or defrost setting.
Does not get power with ac or defrost setting at the fan. So the fan should be fine.
Old 03-18-2010, 06:17 PM   #10 (permalink)
Just because the car will run with either doesn't mean everything will work correctly. I have put different ones on my '02 Escort to see if they would start the car, and even though the car will run all the accessories will not work correctly unless it's the original part number. I have also compared the circuitry on different models opened up side by side and there's definitely a difference.
Unless I am mistaken they changed the CCRM model number on the ZX-2 sometime in the middle of the '98 year model, so one from a late model '98 is probably the same as '99 up, but an early model '98 is different. On the regular Escort one from a '97 will not work on anything '98 and up. I have also seen 3 or 4 different part numbers used on '98 up and I have also compared the circuitry in some of them (opened up side by side) and they were different.
Electric vs. belt driven cooling fan Gregte EcoModding Central 58 04-11-2012 02:20 PM
[CRXMPG Mailbag] Radiator Fan Switch SVOboy EcoModding Central 10 04-14-2011 05:25 AM
LED indicator help Chalupa102 EcoModding Central 10 12-12-2009 03:49 PM
Fan tool (special tool for fan removal) GasGuage DIY / How-to 5 01-01-2009 01:47 PM
Honda civic fan speed control possible mod Vince-HX EcoModding Central 0 08-17-2008 10:48 PM
