Old 11-18-2011, 02:38 AM   #1 (permalink)
i'm dead-set on tailgate up!..... (verified on downhill coasting test!)
I tried tailgate down on a steep 3 mile mountain.The first time going down,tailgate up in neutral, i gained 17 mph.The second time,exact same downhill coast speed,tailgate down, i only gained about 10 mph.i'm convinced!!!
The Following User Says Thank You to sc2dave For This Useful Post:
PaleMelanesian (11-18-2011)
Old 11-18-2011, 02:39 AM   #2 (permalink)
Next, i will try grill block and airdam. This is on an '87 Toyota truck,5 speed
Old 11-18-2011, 10:06 AM   #3 (permalink)
Quite a difference.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 11-18-2011, 10:31 AM   #4 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Sweet! Will you be putting an aero topper on to test? That would be interesting.
Old 11-18-2011, 02:03 PM   #5 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Why don't you buy a $12 piece of 1/2" OSB and just cover the rear most 4' of your bed. Sort of a cheapo half Tonneau cover thing.
The Following User Says Thank You to ChazInMT For This Useful Post:
Cd (02-17-2012)
Old 11-18-2011, 02:21 PM   #6 (permalink)
Hypermiler
PaleMelanesian's Avatar
PaleCivic (retired) - '96 Honda Civic DX Sedan
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Thanks for this! Someone at another forum was just asking about this, in his old Toyota truck.
11-mile commute: 100 mpg - - - Tank: 90.2 mpg / 1191 miles
Old 11-18-2011, 03:11 PM   #7 (permalink)
what's osb,where do i buy this?
Old 11-18-2011, 03:16 PM   #8 (permalink)
Sven7's Avatar
Google says oriented strand board, aka chipboard, plywood etc.
Old 11-18-2011, 04:30 PM   #9 (permalink)
Aero Deshi
ChazInMT's Avatar
OSB is the stuff they use for building houses, I think it's better than plywood in that it does not delaminate. It comes in 4'x8' sheets and you cut it with anything you'd use for wood. It is available at any local lumber store catering to builders. The 1/2" is usually 7/16" thick.
It is all exterior grade, so it will take a long time for the weather to affect it, it is very strong compared to the coroplast everyone seems to be enamored with in this forum. You don't need to do anything to reinforce it if you just use it as a cover. If you want to put anything on top of it that's very heavy, you'll want to put some kinda frame work under it. If it works for you and you plan on using it, you can paint it to keep it in good shape for a few years. And for a quick half tonneau cover, you can't beat the price. The only trick is coming up with a way to secure it to the bed of your truck.
Old 11-18-2011, 05:53 PM   #10 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
You should try the tailgate in various slopes...
Dark Aero-The world's first aerodynamic single wheel boat tail!
