Old 03-02-2014, 08:27 PM   #1 (permalink)
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Grill Block 2.25% Increase @ 50 mph.
After the air dam failing to gain mileage, I decided to go another route while I ponder the air dam some more.
I went to Home Depot, bought some 7$ flashing and then made a cardboard template. Using the license plate bracket and some leftover aluminum angle, I fabbed up some quick mounting brackets. I also put some angle inside the bottom grill opening to hold the bottom of the flashing in. Once the cardboard template fit, I traced it onto the flashing. I then used some self tapping screws to hold the flashing to the brackets.
Here is the pic I took.
Coolant temp stayed right at 195-200*, which is normal. I'll be sure to watch it as the weather gets warmer.
After ABA testing tonight at 50 mph, I got an increase of 1.7% one way and 2.8% increase the other way. Average gain was 2.2%. That is about 1 mpg at 40 mpg. Hopefully the net gain will be higher the faster the car goes. I am out of time to test until next weekend though.
It will take a few miles (4,000) to pay off, but I'll take the gain! I am going to paint it black when I get a minute so it doesn't stick out as much.
The Following 8 Users Say Thank You to sarguy01 For This Useful Post:
Cobb (03-03-2014), jeff88 (03-03-2014), mcrews (03-03-2014), MetroMPG (03-04-2014), mikeyjd (03-05-2014), Piwoslaw (03-03-2014), redpoint5 (03-03-2014), UltArc (03-02-2014)
Old 03-03-2014, 07:46 AM   #2 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Nice work. Congrats with the good result.
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 03-03-2014, 08:18 AM   #3 (permalink)
Dont forget half the upper grill too. Air dams work best with use of grill block. You want to prevent as much air as possible from going through or under the engine bay. If you jsut do an air dam, then most is sucked through the grill do to the vacuum effect it creates.
Old 03-03-2014, 08:28 AM   #4 (permalink)
sarguy01's Avatar
I ran out of time for the upper grill. It is on the to-do list.
So, what your saying is I need to throw my air dam back on and go test again?? The dam is already made. It takes 5 minutes and 8 screws to put back on.
Old 03-03-2014, 12:50 PM   #5 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Looks a lot like mine . . . .well, you used the same material anyway!
For the 7 dollar roll of flashing, you should also be able to do the fender skirts.
Old 03-03-2014, 02:37 PM   #6 (permalink)
sarguy01's Avatar
Oh yeah, 10' of flashing will go a long way...
Old 03-03-2014, 07:51 PM   #7 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Looks good! Definitely put an upper grill block on when you get a chance. I found that in the summer, I needed a cooling slot maybe 12"x2" is all; I situated it about where the bottom of the license plate is.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 03-03-2014, 09:59 PM   #8 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.3 mpg (US)
If you paint it, your payoff will 4,050 miles!
Nice work, hopefully after a tank or two of highway speeds, you'll see a better gain. I wouldn't do the upper until you know what temps. do to engine temp with the current block. Either that or make it super easy to remove (like pull over and be able to unclip it easy).
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 03-04-2014, 12:09 PM   #9 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
What made you go with metal flashing material rather than coroplast?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 03-04-2014, 12:14 PM   #10 (permalink)
sarguy01's Avatar
It is cheap and easy to work with. I cut it with EMT shears.
